Like Tree31Likes
Futaba 4PX
Old 05-25-2017 | 04:19 AM
  #2221
firemanfires's Avatar
I had this same problem and it was the battery.
firemanfires is offline
Old 05-25-2017 | 06:08 AM
  #2222
Thanks! Fingers crossed mine's the same.
OliOC is offline
Old 06-08-2017 | 05:08 PM
  #2223
Mopar2Ya's Avatar
Does anyone have a Maxline offset aluminum wheel? If yes, do you like it?
Mopar2Ya is offline
Old 06-16-2017 | 03:00 PM
  #2224
I just picked one up and need receivers. Which ones work best. I was told to stay away from the fast.
nbkioo8 is offline
Old 06-19-2017 | 11:10 AM
  #2225
darnold's Avatar
2017 Updated data from Futaba Tech (Steve) just this morning:
A) Futaba Fasst Rx has lower Latency than S-Fhss Rx (he said my estimate of .03ms was "about accurate")
B) Fasst Rx's have nearly twice the Resolution of the S-Fhss Rx's
C) Fasst Rx's potentially drop fewer data packets.
D) Fasst Rx cost 2-3 times more (614E = $100 vs 204E = $40)
darnold is offline
Old 06-19-2017 | 01:30 PM
  #2226
Cool
A) Futaba Fasst Rx has lower Latency than S-Fhss Rx (he said my estimate of .003ms was "about accurate")
Can you translate that? Are you basically saying that fasst receivers are better by you pay much more?
nbkioo8 is offline
Old 06-19-2017 | 02:47 PM
  #2227
darnold's Avatar
No. Fasst rx's are faster due to the protocol used.
More importantly they have virtually twice the resolution.
Using a Fasst rx probably gets the 4PX around the M12 to possibly inbetween it and the M12S for latency. The resolution with a Fasst rx should be as good as the M12/M12s from the conversation.
It seems that the Sanwa systems have been using the Fasst type hybrid protocol (I believe it's a Dsm + Fhss type) for some time, even though Futaba appears to have been first to market with it. Sanwa seems to call it Fhss 3 and 4 instead of Fasst (probably due to Futaba patents/copyright). The differences between the two companies would be in the programming of their systems using the hybrid protocol. I told the Futaba tech that I didn't understand why Futaba was letting others dictate the terms of how their product was being characterized when they could have just released the info. The tech said that he would present this up the chain.
Note: I meant .3ms not
.003ms for the potential difference in latency between the Fasst and S-Fhss rx's. It should also be noted that the Futaba tech didn't have the exact differential figure, but he knew for certain that the Fasst rx is faster than the S-Fhss and thought my estimation sounded fair. Lol.
For me the virtual doubling of resolution (about 98% more roughly) is even more important than the decreased latency. That increased resolution, along with better error correction should really improve feel.
darnold is offline
Old 06-19-2017 | 09:22 PM
  #2228
gardey's Avatar
can anyone tell me why my R614FS receivers wont bind with my 4PX ???
gardey is offline
Old 06-20-2017 | 02:19 PM
  #2229
darnold's Avatar
It should work fine I believe. My 614E worked with no problem.
Therefore, assuming power is being given to the rx, , then I would check the following:
1) Fasst rx setting is selected under "Receiver" within the Tx menu and leave your Tx on at this menu.
2) When you turn on the Rx it should start flashing green.
3) When/If you get a message on your Tx asking you about resetting any failsafe say "Yes/Accept".
Your Rx should bind and the LED should turn solid green.
What is yours doing?
darnold is offline
Old 06-20-2017 | 03:06 PM
  #2230
adrictan's Avatar
Then between FAAST vs T-FHSS?
adrictan is offline
Old 06-20-2017 | 06:43 PM
  #2231
darnold's Avatar
T-Fhss is just Fhss with telemetry from everything I've been able to find. Information that I've come across indicates that there is an increase in latency with the telemetry turned on (you can turn it off in the Tx). The Fasst protocol is simply faster than the Fhss based protocol, whether it is S-Fhss, T-Fhss, or basic Fhss. Of the stock Fhss protocols from Futaba the S-Fhss is fastest.
This is of course for Futaba receivers; Sanwa receivers have a hybrid technology that is basically like the Fasst but they still call it Fhss (3&4).
I'm sure that a Futaba rep can chime in on all of this as well.
darnold is offline
Old 06-21-2017 | 04:38 PM
  #2232
gardey's Avatar
I've selected FASST 2.4 in receiver selection & followed procedures as instructed. The receiver stays red.I push the receiver button & it flashes red .then stays red.
gardey is offline
Old 06-21-2017 | 04:46 PM
  #2233
gardey's Avatar
Default No support from Futaba Aust or US
If you purchase a Futaba in Australia beware that you will get no support from anyone in the U.S. or Australia.
I would not recommend Futaba after my recent experiences trying to get help. The wholesales dealer in W.A.apparently expects that all buyers to investigate the dealers to ascertain the origin of the products' importation.
They won't assist at all.
U.S. were slightly better but won't answer the support line & if you're from overseas , again, it's not their problem.
Sanwa next time for me I think.
gardey is offline
Old 06-22-2017 | 12:39 AM
  #2234
Is it true that you can't run a lipo with this radio?
nbkioo8 is offline
Old 06-22-2017 | 02:05 AM
  #2235
gardey's Avatar
No idea.i have a life in it
gardey is offline
