Like Tree31Likes
Futaba 4PX
Old 03-05-2019 | 01:21 PM
  #2356
Roelof's Avatar
I think if you know how to handle a screwdriver (because this hobby I think you can ) you can replace it yourself.
Only in a quick search I did not find a replacement screen
Found it:
https://nl.aliexpress.com/item/Tarot...14b3e771d319-6
JRSlash likes this.
Roelof is online now
Old 09-22-2019 | 07:11 AM
  #2357
laccuuuuuuu's Avatar
How do you fix this?
laccuuuuuuu is offline
Old 09-22-2019 | 07:16 AM
  #2358
Default How do you fix this?
Originally Posted by ck960
Hi guys, my friend encounter this error on his 4px, he is not charging battery on the tx and have try unplug and plug in battery few times, still same.
As per manual need to send in for repair.
Any way can fix this, thanks in advance
How do you fix this ?
Old 09-22-2019 | 07:26 AM
  #2359
1/8 IC Fan's Avatar
Takr it apart... get the right part, reassemble.... not hard.
1/8 IC Fan is offline
Old 09-22-2019 | 08:06 AM
  #2360
Roelof's Avatar
In some charger connections a diode is placed to prevent wrong polarity. When charging too much current this diode will be blown. Most of the time this diode is close placed to the charge connector.
Old 10-04-2019 | 06:09 PM
  #2361
Default Race mode??
Under the response tab there is a switch for race mode what does it do??
Iggy 102 is offline
Old 10-13-2019 | 02:20 PM
  #2362
Hello, I have r304sb receiver, it is 4 channels and there is a channel that puts s-bus2. I have servo futaba sbus2.
My question is, does the sbus2 servo connect to its channel where it always (channel 1) or does it put on the channel that commented the one that puts sbus2 that is in blue?
What is that channel worth?
Thanks and best regards
electrojer is offline
Old 10-13-2019 | 11:08 PM
  #2363
Roelof's Avatar
I think both is possible. On the SBUS you can program the servo to any channel. I know on the 7PX/7XC there is a port on the transmitter you can use to connect and program the servo's, Look into the manual if the 4PX has the same
Old 12-27-2019 | 12:39 PM
  #2364
just got a 4px ... where is the EXPO or curve adjustment feature in this radio... coming from SANWA
Phillip F is offline
Old 12-27-2019 | 12:47 PM
  #2365
Roelof's Avatar
Page 56
http://manuals.hobbico.com/fut/4px-manual.pdf
Phillip F likes this.
Old 12-27-2019 | 12:53 PM
  #2366
Move the button in the middle to the right, menu comes up, look for EXP. Adjust as needed.
mooby64 is offline
Old 01-04-2020 | 06:24 PM
  #2367
nexxus's Avatar
Super Moderator
Has anyone had any issues with the centre button / joystick thing on these? On one I have here it sticks horribly, wasn't even working when pushed down, opened it up and a bulk load of contact cleaner has helped (can kind of navigate menus now) but still sticks a lot, changing a model name would be an hour job lol
nexxus is offline
Old 01-28-2020 | 12:58 PM
  #2368
Same as mine, and I did what you did. I pray that it won't happen again. Because I have no other solution. It works very well since it happened, around 1 year
Alentino is offline
Old 01-28-2020 | 01:00 PM
  #2369
Originally Posted by kostas xray
Hi to all my 4px in the middle of the race suddenly freezes.no thrrotle no steering i try to turn it off and nothing i could not to turn it off so i disconnect the battery then i recconect it and everything was fine.software version is 1.4e and i use lrp life battery 6.6v.any ideas why this happen?
Alentino is offline
Old 01-28-2020 | 07:55 PM
  #2370
HI, can anyone confirm if you can do this in with 4PX? I just bought a Futaba S9373 SErvo. Can you program that servo with 4PX?
thanks!
rbc626 is offline
