Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 09-14-2013 | 08:17 AM
  #1096
Is Tekin going to package this esc with the T8i motors in a combo pack?
Rufus2010 is offline
Old 09-14-2013 | 08:28 AM
  #1097
darkstar1974's Avatar
Originally Posted by florianlaux
I have a problem:
I ran a Gen2 with 1900 Tekin motor in a EB48 with 17 pinion. Savöx 1267 Servo Sanwa M11X radio. 4S 7200 CS Racing Battery.
No boost no timing. BEC 7,4Volt 3,4 Volt cutoff per cell. deadband 15
We run 15 minutes mains and after 13 Minutes the car just stoppt. engine had 100 degree Celsius and speedo 90 degree celsius. After switsching the car of and on....everything was o.k. but my main was done.
Any sugesstions???
I'm assuming you meant 100 and 90 degrees fahrenheit? Otherwise those temps would clearly be an issue.
If the temps are fine sounds like a battery or possibly a charger issue to me. Is it an older pack? Have you checked the IR on it recently? Do you check the voltage of the pack after you charge it? Maybe your charger has an issue and isn't fully charging your pack. 15 minute mains are pretty long, but I would think a 4s 7200 pack should be able to make that with your current set up. I'd defintely start with the battery/charger and go from there.
darkstar1974 is offline
Old 09-14-2013 | 08:40 AM
  #1098
fq06's Avatar
Oh yeah, didn't catch that John... 100°c is 212°f and 90°c is 194°f.
I believe thermal cutoff temp on the ESC is 160°f.
fq06 is offline
Old 09-14-2013 | 09:32 AM
  #1099
ChuckTee's Avatar
Hey guys I have been having a problem with changing the settings on my RX8 G2's timing, I use the push button mode and select the timing level and once I hit the increase button all the led's light up and nothing changes. It just keeps showing the timing led and then the level 1 led. I can't get it to change. Any suggestions? Thanks in advance.
ChuckTee is offline
Old 09-14-2013 | 12:32 PM
  #1100
Randy_Pike's Avatar
Team Tekin
No, that would simply create too many part #'s for dealers and distribution to stock.
Randy_Pike is offline
Old 09-14-2013 | 12:33 PM
  #1101
Randy_Pike's Avatar
Team Tekin
I have a problem:
Any sugesstions???
First off your LVC should be set for total pack voltage, it's not per cell.
13 minutes in a run, you hit voltage cut off.
Old 09-14-2013 | 12:34 PM
  #1102
Randy_Pike's Avatar
Team Tekin
No, thermal cut off on the esc is in the 240f degree range.
He didn't thermal.
Even with 7000's he's likely dumping at 13 minutes I'd wager.
When you charged the batteries, how many mah did they take?
Old 09-14-2013 | 12:35 PM
  #1103
Randy_Pike's Avatar
Team Tekin
To change a timing profile you must hit the "mode" button 5 times to move the led over to TP. Then hit the "inc" button to select the timing profile you want. Led's 6 and 7 are custom ones.
Old 09-14-2013 | 12:43 PM
  #1104
ChuckTee's Avatar
That's what I am doing and when I hit the increase it lights up the whole led bar and doesn't change a thing.
ChuckTee is offline
Old 09-14-2013 | 12:49 PM
  #1105
ChuckTee's Avatar
I was waiting too long to press the increase button. Go figure, thanks for bearing with me and the slow brain. I think I was dropped as a baby! Just kidding....I think.
ChuckTee is offline
Old 09-14-2013 | 03:45 PM
  #1106
trixter91's Avatar
Is it possible to use the gen2 software with rs and rspro with the 9.6 software.
trixter91 is offline
Old 09-14-2013 | 04:30 PM
  #1107
ChuckTee's Avatar
Randy thanks for the help. That's why I like this forum, people are actually here to try and help eachother out.
ChuckTee is offline
Old 09-14-2013 | 04:56 PM
  #1108
fq06's Avatar
He didn't thermal.
Wow, that's impressive that it can take that kind of heat.
fq06 is offline
Old 09-14-2013 | 08:28 PM
  #1109
Randy_Pike's Avatar
Team Tekin
The Hotwire 9.6 will read Gen1 esc's, yes.
You however cannot load Gen2 software onto a gen1 unit.
Old 09-14-2013 | 08:53 PM
  #1110
MrMorninwood's Avatar
I just got my Gen2, and downloaded the Hotwire software.
I am running windows 8 and can't seem to get the hotwire window any bigger.
I can't read half the settings.
Is there something I'm missing?
I can right click on the top bar of the window but it will only allow me to move the window, not resize.
MrMorninwood is offline
