Official Tekin RX8 GEN2 ESC Thread
#1127
Then I would prep the surfaces REALLY good before you apply the tape or Velcro . Clean both the chassis and the bottom of the ESC with alcohol (denatured is best) or acetone (becareful some plastics dont like it) . I have some buddies that swear by that heavy duty Velcro ....
#1128
Hay Randy or others,
What's the best way to mount the esc to the chassis? I have used padded servo tape and other double sided tape but once dirt gets in there around the bottom of the esc, it eventually comes off. After it comes off I usually put a bead of shoe goo around the bottom. Should I just keep doing that or is there a better way.
I have seen people use some really hard plastic Velcro from Walmart. I don't know if that works or not.
Thanks guys
Thanks guys
#1130
Thanks guys
Thanks guys
#1131
I've used shoe goo for about 6 months now for my gen1, plastic fab'd up plate goo'd to the chassis and esc goo'd to the plate. Got tired of multiple brands of tape letting go after a while. This is on my Mugen SCT conversion so there is no ESC tray, had to make one.
No issues with the ESC, still going strong. I have heard people warn about this as it does not absorb shock as well as a servo tape but my ESC will not move unless I pry it off.
Maybe the two layers of goo is adding some shock absorbtion that's needed to not kill the ESC.
#1132
Hideeho
I have a question regarding warranty work on an ESC purchased from ebay. If I buy an ESC from a seller on ebay that lists it as new, how does Tekin handle the warranty? what do I need to provide for it to be covered?
I am not in this situation, but I am considering savings a few $ on an ebay deal for a "new" ESC.
#1133
This forum is great for figuring things out. As I was setting the gen2 rx8 I went to my rspro with the hotwire to see what one of the settings were and I noticed in the dashboard it said on the bottom left race spec lock on. So I went into the timing tab and the race spec box is not checked. Anybody know how the race spec mode could be on if the box isnt checked cause my other rspro says race spec lock off and all my settings are the same. Anybody have any ideas.
#1134
The main ? would be how many mah did the batteries take after that run.
#1135
#1136
For mounting ESC it doesn't get much better than the Kyosho Zeal Gel. Sticks like crazy but when you need to take off just slide a flathead screwdriver under it to remove from chassis and just peel off ESC. It's $14 for a small sheet good for mounting 2-3 esc's
#1137
Hideeho
#1138
#1139
Would I just send a screen print of the sale as a receipt? Is there a specific way to find out if a seller is distributor, or just use common sense?
For example, I assume one of these is a distributor & the other isn't.
http://item.mobileweb.ebay.com/viewi...d=221283289341
http://item.mobileweb.ebay.com/viewi...d=121171328181
#1140
Ok that makes sense so obviously locked spec mode would be done by checking the lock spec mode box, how do I turn off reg spec mode as I didnt know how I turned it on.
20Likes
