SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 08-02-2015 | 01:07 PM
  #3751
racer1812's Avatar
Super Moderator
Originally Posted by radioctrlhead
Got some questions for you guys. I have two 2s 6500 packs that haves about 8 cycles through them each. I have never take them below 3 volts but find that the balance charge time take a very long time. the largest pack I had before this was a 5000 and they would peak a lot sooner. I'm running a hitec X1 at 6 amps and monitor it closely. It will usually stay at 4.2 volts for a while before it peaks and I'm wonderinf of anyone else has experience with this? If both cells are more or less close to capacity and balanced should I just shut the charger off or should I wait until the charger makes that determination? Total charge charge is usually over an hour and a half and start from about 3.4 volts a cell.
I find that it spends about 30 minutes trickling the last couple hundred mah into the battery before peaking
My 5k (from different manufacture) packs will peak very quickly without trickling every last bit into the battery to determine a peak. Are the 6500 more sensitive in some way?
Sorry for the long post and thank you
Originally Posted by Jerm13
That's normal. Its the software program in the charger trying to get it as close to even, max capacity and voltage as possible.
Have had many packs do this from different manufacturers. And since you have about 8 cycles thru them, they have found their " sweet spot" of capacity. Not a big deal.
Not always. Yes it's (the charger) trying to balance the cells as close as possible. But a pack with quality/healthy cells shouldn't take that long to balance and peak.
I run Hyperion chargers. They balance while charging. If my packs when charged after a normal race run (static 7.4v normally) don't balance before hitting 8.4v there's something wrong with the pack (weak cell). Regardless of brand.
racer1812 is offline
Old 08-02-2015 | 01:10 PM
  #3752
racer1812's Avatar
Super Moderator
Originally Posted by braderb
Regarding 2 cell Dean batteries. Personally needed for my 4wd SC SCTE.
Some time ago I remember reading that the 6500 is better for racing than the 7200.
It was a detailed write up from SMC. Went searching at beginning of thread with no luck finding it.
By default, we buy according to the biggest number. But, 6500 was preferred. Not sure why {power/burst} ?
Can I get clarification before I buy. Strictly for racing only-not a basher.
THANKS
Most likely because the 6500mah packs had lower IR. That's my educated guess and not from experience. The extra 700mah of capacity does you no good if the IR is higher.
Old 08-03-2015 | 07:45 AM
  #3753
Packs and charger are both pretty new. Like I said only 8 cycles, always balanced and never below 8.4 v. Cell. 6 amps is plenty to bring the pack to 8.4 before it begins dropping the charge rate to about .3 /.2 to balance. Only at this point is where I think it takes too long. I monitor the individual cells bouncing from 4.19 to 4.21 but both will balance at 4.2 evenly. It appears the cells mAy be a bit volatile at this point so it confuses the charger. Is there a break in period? Also the charger will vary it's charge to accomidate the volatile behavior of the voltages
radioctrlhead is offline
Old 08-03-2015 | 08:04 AM
  #3754
Originally Posted by sobiski racer
Also you are not even charging at one c. Ideally you charge 6500 at 6.5 amps for a one hour charge time. I would charge at 13. 10 amp minium
I think charging at 6 amps is plenty. What appears to be taking a long time is at the second stage of the charge cycle which drops the charge rate well below 2 amps. it trickles at 0-.4 amps to find that balance, this part is taking longer than i'm used to. Then again i've never played with a 6500 mah battery before. I have two more on the way and will see how those behave.
Again, I've been monitoring these batteries closely. and the charger is brand new
Old 08-18-2015 | 02:27 PM
  #3755
Coppercanyon's Avatar
SMC batteries are now available at CRPplus.com,,,great batteries at a great price
Coppercanyon is offline
Old 08-18-2015 | 04:02 PM
  #3756
Not really sure whats going on, but these 6500 mah batteries will not peak. something is not right with them. oh well.
Old 08-18-2015 | 06:23 PM
  #3757
Have you attempted to contact Danny at SMC?
drivercorycraig is offline
Old 08-18-2015 | 06:30 PM
  #3758
Matt Trimmings's Avatar
less than 1c charge rate is plenty?
Matt Trimmings is offline
Old 08-19-2015 | 01:09 PM
  #3759
Yes, he actually got back to me within minutes. He said that some chargers will take longer to peak or not peak at all depending on the calibration settings and the resistance of the cells. He says it's very common with cheap chinese chargers and said to just pull the packs off the charger when both cells read 4.2 volts and the charge rate is well below 1 amp.
My question to you everyone is, What chargers are you guys using and do the packs peak in a timely manner everytime? I thought maybe the size of the packs i'm using (6500 mah) may be the reason why.
Old 08-19-2015 | 01:40 PM
  #3760
peaking can take a while
bring it on is offline
Old 08-19-2015 | 02:52 PM
  #3761
WIGMAN's Avatar
I use this one, works great and it will charge at up to 12 amps.
http://www.amain.com/rc-cars/protek-...k-8510/p260576
WIGMAN is offline
Old 08-19-2015 | 04:12 PM
  #3762
Interesting that I came on here to read some peoples thoughts and one of the first was this. I have actually moved away from SMC for this, and other, reasons. No other battery I own takes as long to balance. Furthermore, 1 of my 6500's had a balance wire break off after 2 runs. the 4600mah 4s shorties seemed puffed when i got them but I was told they were just tightly packed.... the case split at the seam not long after buying them. 1 of my 6500's has a cell that looses charge over time (put in storage for maybe a month and the cell was at 1.5v)
I have also noticed that it seems 1-2 cells on each pack has a higher IR (30 vs 4-6 for the other cells), which makes me think that is the reason for the slow balance times. I know when I first got them they balanced fine for about 5 times. once I had used them maybe 20 times each and I gave up on them. I now use Protec and intellect and haven't had an issue. I still get the SMC's out for practice (as we don't have permanent power at the track, so taking as many batteries as possible is always best). the SMC's have nowhere near the punch of the others and they don't last anywhere near as long. all my batteries will now be around the same use (but maybe 6mths difference in age). All in all I have been extremely disappointed.
In answer to your question, I use a Junsi 308 at home and a skyrc 2 x 400w at the track
revhead145 is offline
Old 08-20-2015 | 05:40 AM
  #3763
hacker's Avatar
Default shorty
am I correct in saying SMC had 4600 shortys, and then the latest one is 4400?
why with the lesser capacity?
hacker is offline
Old 08-20-2015 | 08:13 AM
  #3764
I thought the same thing but he did say 4s packs. Are you looking at 2s packs?
Old 08-20-2015 | 08:56 AM
  #3765
That is correct, he no longer has the 4600mah Now it is 4400mah and that is what I run myself.
