SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 08-20-2013 | 06:59 PM
  #2251
So I think I have my second issue.
I bought (2) brnad new packs about 3-4 weeks ago. (1) pack would fully balnce charge to 4.20 volts cell 1 and 4.20 volts cell two. SEcond apck would only charge to 4.19volts cell one and 4.20 volts cell two. No big deal still worked great.
Trying to charge my packs before the race tomorrow and charged the first pack to 4.2 volts cell one and 4.2 volts cell two. Went to charge the second pack and Charger started screaming at me. Shows 1.5 volts cell one and 5 volts cell two. Unplugged charger and plugged back in thinking that might be the problem and registered same thing. Plug first completely charged battery back in and it reads 4.2 volts per cell. Is my pack dead or am I doing something wrong?
I run a tekin Rx8 gen2 with cutoff set at 3.8 volts per cell or 7.6V total. Not sure whats wrong is this is probably the 7-8th charge total on this pack.
Bignose94015 is offline
Old 08-20-2013 | 07:07 PM
  #2252
fq06's Avatar
I would think the plugs are not the issue since your charger is not having a problem with one pack but...
Just for the heck of it, if your using banana plugs, see if you can spread out the cage a little to get a better contact. I use solid bullets on my charge leads, the PowerLab charger does not like the bird cage plugs. False readings or something and it sporadically will not charge with the bird cage plugs.
Just a thought to try out, 1.5v & 5v sounds like a bad read. Can't see a cell getting that low or high in voltage. You balance charge right?
fq06 is offline
Old 08-20-2013 | 07:15 PM
  #2253
STLNLST's Avatar
Originally Posted by Woulvesbaine
For 17.5 Stock Buggy Class (b4.2), do you suggest the 70c shorty? I could use a little extra punch to get over that double at WCRC that follows the sweeper.
Also any recommendations for care? I see a ton on the forums and would be interested to cut through it all and hear from the people involved in purchasing and testing these.
Break in? Storage thoughts? Nothing special?
What pack are you currently running now?
STLNLST is offline
Old 08-20-2013 | 07:35 PM
  #2254
Balance charge deans connectors.
Old 08-20-2013 | 08:03 PM
  #2255
fq06's Avatar
Never mind then
If Danny doesn't have anything for you, maybe replace the deans? That's so off it sounds like a connection issue.
fq06 is offline
Old 08-20-2013 | 08:53 PM
  #2256
Woulvesbaine's Avatar
Originally Posted by Banshee8530
Danny encourages stock racers to use 4600-70C pack for the very reason you state. I have one and it is quite impressive. Performs better than my Protek full size 2s used to.
These batteries can be charged at 2-3C with little issue. Higher than that can be done but you won't get a complete charge.
No break-in necessary. Charge it and go.
Recommended storage voltage is 3.6-3.8 V per cell. That info is listed in the instructions that come with the pack.
Thanks for the quick and thorough response!
Woulvesbaine is offline
Old 08-21-2013 | 01:20 AM
  #2257
ImageX's Avatar
3.8 cut off?? Why? You are losing tons of run time for no reason. At least you can run your RC to cut off and then your packs are already at storage voltage. I set LVC to 3.2-3.4.
My gap volts on my SMC 4S packs are .001.
ImageX is offline
Old 08-21-2013 | 08:54 AM
  #2258
Still in rookie, 4 min quals and 5 min main. Makes it easy to leave them at storage voltage.
Old 08-21-2013 | 11:29 AM
  #2259
Just got my 2 saddle packs in the mail and can't wait to hit the track tomorrow. I also got a nice suprise back, I look forward to doing some more business as my 2WD SCT is in need of some new packs as well. Thanks Danny/SMC
flintTRDTC is offline
Old 08-21-2013 | 11:31 AM
  #2260
Thinking about running the shorty packs in my 2WD SCT. Anyone running them in their 2WD SCT? How do you like them?
Old 08-21-2013 | 12:14 PM
  #2261
Just seen this posted by SMC on there FB page!
SMC Racing
I'm pleased to announce that SMC is now a sponsor on RC Groups and we have our own section in the Vendors forum.
For those who have been following me on RCtech I had a difference with the people running that site and they even suspended me. I will no longer post on RCtech even if they remove my suspension.
Questions can be asked in the thread son RC Groups or on our Facebook page.
moparfan1234 is offline
Old 08-21-2013 | 12:16 PM
  #2262
Thumbs down
Well, that sucks... A bad on rctech to have a problem w/ the best battery vendor out there..
SMC Racing
bwolfsohn is offline
Old 08-21-2013 | 12:25 PM
  #2263
YEP! I figured some one needed to post it so everyone that is only on the forum could see where he went
Old 08-21-2013 | 12:45 PM
  #2264
fq06's Avatar
That's just wrong. Rctech must have been squeezing him for money. They pushed out one of the most informative people about one of the most mysterious products (lipo).
Wouldn't think Danny would be offensive to someone but looked at his recent posts and as I thought, nothing said that should cause a ban. Unless mods deleted it... but I doubt there was anything to delete.
fq06 is offline
Old 08-21-2013 | 12:52 PM
  #2265
mydudrevo's Avatar
SMC Racing
That's a bad call IMO. Rctech brings smc a lot of business with the amount of traffic through here. Just suck it up and fix what ever has caused this disagreement because its going to cut into your sales if you dont
mydudrevo is offline
