HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#9481
Hobbywing Ezrun 150a ESC losing power
Hi, I'm running the Hobbywing 150a ESC with a Toro sensorless 4600kv motor, it runs fine for about 5mins or so then seems to lose power when i apply any Throttle. It does'nt stop completely just loses about 95% of it's power but if i go off and on with the Throttle or roll to a stop and hit the Throttle again it seems to go back to full power again. Any advice muchly appreciated. Cheers
#9482
#9483
so i got sct pro esc in tekno eb48 and put savox 2274 hv servo and got 1 race before my radio said 3.8 voltage... battery in car and radio fully charged..so did it burn out my esc...radio works on my other sct 410 tekno,same sct pro esc,...
Also tried different servo and receiver still does the same..when i wiggle steering back and forth,thinking capacitor is shot?
Thanks Jeff
Thanks Jeff
#9484
Thanks Jeff
Thanks Jeff
#9485
#9486
1- 5 min race then 2nd race radio went to safety... 3.8 volts flash on radio ? not enough power for radio.
ok R1joel i'll try that...Thanks don't remember if i ever did that it's been in there for 2 years..lol no updates,,always worked good until new servo.
#9488
#9489
I am running a Xerun stock spec V3.1 ESC with my 4pls in mod buggy. The question I have is what do I need to do to the ESC if anything to get my car to stop? It just wants to coast when I apply the brake and I have been messing with the end points and all of the brake settings on the Xmitter. Any help that anyone has would be great.
#9490
Thanks Jeff
Thanks Jeff
#9493
Max 8 Major Fail?
Tell me this is something simple, but I can't figure out what's wrong.
Out of the box, Max 8, just hooked it up. Power it up (4s) and the ESC powers up, but no power is delivered from the ESC to the receiver (no steering, no light on the rx, and the transponder is not flashing). When I unplug the ESC from the receiver, the fan starts up. Plug it back in, the fan shuts off.
Problem with the speedo, or some quirk I am overlooking. Baffled here...
#9494
#9495
Wish I could. Since the ESC won't power up the receiver, the ESC doesn't receive any signal from the radio to calibrate to.
Also, I tried hooking up both my program box, and the program card that came with the ESC. Neither one works. I get "connecting" on the box, and all dashes on the card.
The most troubling thing is that the fan shuts off when I plug the wire into the receiver. Something has to be very wrong.
Bad ESC out of the box? Not good.
