HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#7982
Hobbywing 3.1 setup for carpet (2wd and 4wd buggies)
Hi all,
I am posting here because I would like to have a good based setup for my esc hobbywing 3.1.
I am racing 2wd and 4wd on a medium size carpet track, so it is medium-high bite and has a combination of low and high speed corners.
For the moment I have been unable to find a right setup and I have the impression that I still have too much puch, brake, ...
It would be fantastic to have a full setup to know also turbo timing, boost, acceleration curve, etc
Someone has a good based setup for carpet 2wd and 4wd?
Thank you in advance
#7984
Yes, I have done it and I understand the basic concepts, however what I am looking for is a good mix of parameters! Because I guess if have have very low punch but at the same time the turbo starts very low, I will still feel a lot "punch" in the car.
In TC I managed to find a nice setting based on one base setup I found and doing some small adjustments, but I am struggling with my buggies.
Btw one more specific question. Which profile would you recommend for buggies? "Mod" or "SCT/buggy"? My question is because I have seen people using both but I guess the "SCT/buggy" is a better starting point, am I right? I have heard that "mod" works better with modified motors... But still I am not sure...
Thank you in advance!
#7986
I've been using the older 120a V2.1, Black and is currently in Blinky Mode.
I was playing around with with my program box. I was prompted for the update, but it appears its for the v3 versions.
My question is, I Have only 2 software versions showing, and I thought there were others, ami I crazy?
-Software
-V1.08_120504
-V1.11_120331_V3
I just plan to keep this one in Blinky. Is there a link for the various Software versions that are available, Current and Past? What is the current version for the V2.1? Hardware version for the Box?
I only have the 2 options.
MOmo
-Software
-V1.08_120504
-V1.11_120331_V3
MOmo
Thoughts?
#7988
XERUN 120A 1S V3.1 ESC
Does anybody know if the XERUN 120A 1S V3.1 ESC can be run with a 2s Lipo? I know it says in the instructions not to use it but on the other hand it mentions the use of Touring Car use and voltage cut offs up to 11.1V? I have the V2.1 and it works just fine on the 2S LiPo. I would like to use it on a 17.5 Blinky Set up in Stock Touring Car with a 2S LiPo. Any help suggestions would be most appreciated, Thanks
#7992
Hi guy's i was wondering if i can run my V3.1 without the fan?
Running my buggy with a hobbywing V10 8.5T motor on 2S lipo
