HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 10-21-2014, 04:40 AM
  #7951
Slotmachine's Avatar
Originally Posted by TahoeDust
I have heard that HW ESCs are known to hit LVC a little prematurely. I have my Xerun 150a on the default setting (3.5v?). When I got home I put a multimeter on it and got 14.44v on my 4s pack...3.61v per cell. What can I safely run the cell down to?
My questions are: What can I safely run the cell down to? What voltage cutoff setting are you guys running?
I set all my HW speed controls to 3.0 but you can try 3.2V.
Paul
Slotmachine is offline
Old 10-21-2014, 02:20 PM
  #7952
Quick question guys. Can I purchase a new Justock speed control without the program card? Would the speed control still function normally out of the box?
Thanks.
Buggy Convert is offline
Old 10-21-2014, 04:41 PM
  #7953
Ho1aw's Avatar
[QUOTE=FastPete;13601894]+1 no way, thought he was looking for someone to fix it. Probably better off just getting a new one.[/QUOTEthen need a new one.
Ho1aw is offline
Old 10-21-2014, 08:49 PM
  #7954
Scojax's Avatar
Thanks.
I bought a Justock last month. No program card. It works just fine and I can program it without the card.
Scojax is offline
Old 10-21-2014, 09:18 PM
  #7955
Trader Rating: 83 (100%+)
I've got a question for those in the know. I'm running a trinity d4 17.5 with a high Torque rotor. The class I run is all 17.5 but you can run blinky or a boosted speedo. I seem to have quite a bit less top end than the rest. I'm geared 28/76 with 50 degrees of motor timing in a stadium truck. Would I get better performance running boost and turbo on the v3.1 speedo as supposed to just motor timing?
dpcardoza is offline
Old 10-22-2014, 03:12 AM
  #7956
Yes you would get better performance boosted and timed, just watch temps.
Paul
Old 10-22-2014, 03:16 AM
  #7957
Paul
So drop the motor timing to say 20 and then add some boost and turbo to the esc?
Old 10-22-2014, 10:44 PM
  #7958
MOmo's Avatar
I've been using the older 120a V2.1, Black and is currently in Blinky Mode.
I was playing around with with my program box. I was prompted for the update, but it appears its for the v3 versions.
My question is, I Have only 2 software versions showing, and I thought there were others.
-Software
-V1.08_120504
-V1.11_120331_V3
I just plan to keep this one in Blinky. Is there a link for the various Software versions that are available, Current and Past? What is the current version for the V2.1? Hardware version for the Box?
I only have the 2 options.
MOmo
MOmo is offline
Old 10-23-2014, 12:21 AM
  #7959
Hi, I am running b44.2 with HW 6.5 T xerun and v3 esc on a high bite indoor track. Can you please give me recommendation on a good esc setting starting point? My motor tempature after a practice run is around 130. Right now I'm just running the out of box setting. Not sure if there's a better setting that you may recommend.
Thanks!
Gary
loosenut is offline
Old 10-23-2014, 04:55 AM
  #7960
Yes...the lower timing will give you more torque on the bottom end and your boost will give you top end.
Paul
Old 10-23-2014, 10:06 AM
  #7961
FastPete's Avatar
Trader Rating: 44 (100%+)
Thanks!
Gary
Hi Gary,
Im getting ready to do the same thing, same esc and motor, just a DEX410. Im going to start in blinky, 0 timing, boost, and turbo in the esc. Set the motor at 25-30 on the bell and try it. Start simple and go from there. Then I will try some boost maybe but most don't from what im told.
Pete
FastPete is offline
Old 10-23-2014, 02:40 PM
  #7962
I think I'm about to loose my mind. I recently bought a Quicrun 08 150a from my 1/8th Monster Truck after the factory HW 80a WP went up in flames. No matter what batteries I use or settings I set on the ESC the truck will hit LVC within 20 seconds of running(or at least I think so based on behavior and the flashing red led).
I have tried my existing 20month old 50c batteries, a brand new set of 50c batteries as well as brand new 80c Track power batteries. The truck is a CEN Colossus and came with a 2000kv HW motor.
I have discovered that the level 9 programming (motor timing) only has 4 options and not the 8 described in the manual. I'm starting to wonder if any of the settings are what they are supposed to be according to the documents.
Does anyone have some insight?
pfitchie is offline
Old 10-23-2014, 02:49 PM
  #7963
Make sure the lvc is set at 3 or 3.2 on the speedo. That's all I got.
Old 10-23-2014, 02:54 PM
  #7964
Thanks, I've tried even lower with fresh batteries and same problem.
pfitchie is offline
Old 10-23-2014, 03:00 PM
  #7965
Precision1's Avatar
Trader Rating: 51 (100%+)
Default V3.1 cooling fan??
Hey Folks,
I've got 5 HW ESCs (Xerun 150, SCT-Pro, V3.1). They are great and I have had no problems with them.
I am looking to get another V3.1 and want to run it on 4s for a 1/8 buggy project (I currently have a V3.1 running 2S).
I am confused on the fan situation.
SCT-Pro has identical specs (6V/3A BEC), and uses 5V fan. I run 2 SCT-Pros on 4S right now with zero problems.
HW says you must use 12v fan for V3.1 on 4S.
From HW site:
Please choose different cooling fans in different applications.
For 4-6 cells NiMH or 2S Lipo: Needn't change the 5V cooling fan on the ESC;
For 7-9 cells NiMH or 3S Lipo: Please choose a 12V cooling fan or supply the 5V fan from the receiver (+6V);
For 10-12 cells NiMH or 4S Lipo: Please choose a 12V cooling fan, and cut the output of the built-in BEC, then supply the receiver with an UBEC (An additional external DC-DC regulator)Please choose different cooling fans in different applications.
1) Do I really need the 12v fan?
2) Why the UBEC? I run 4S in 1/8 buggy with the SCT-Pro without UBEC.
Someone help me out please, tell me what to buy!
Precision1 is offline
