HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree191Likes
Old 07-27-2015, 06:43 PM
  #9631
Dan.J's Avatar
Trader Rating: 21 (100%+)
How many are running the 120a V3.1 in 4wd SCT with a 4 pole? Thinking of putting one in my Tekno. My issue is I have been running a Orion R10.1 in the truck and can not for the life of me keep a fan on it for more than a heat or 2 and its driving me NUTS! I would like to give the V3.1 a spin as I'm guessing its very similar but am I still going to be dealing with fan issues?
Dan.J is offline
Old 07-27-2015, 06:55 PM
  #9632
Trader Rating: 20 (100%+)
belive that would fry it, not setup to handle a bigger truck. But we'll see what the pro say
jakeg1973 is offline
Old 07-27-2015, 06:57 PM
  #9633
Slapjack's Avatar
Trader Rating: 19 (100%+)
I got the esc calibrated. I hooked up the program card and made a couple adjustments then decided to try calibrating one more time before I went upstairs for th night and it worked.
Now am I reading the manual right when it says I should not use the lipo cell auto detect? I should program the actual 4s or whatever I run in the program card? I will most likely be using 5s. And I set the cut off to 3.4v.
Also wondering if there is a way to adjust the voltage going to the servo. I hav a savox 1256 which is a 6 volt servo. I think I saw that the xerun 150a is set to 5.75. Is that max? Or can it be bumped up to 6v?
Slapjack is offline
  #9634
Originally Posted by jakeg1973
I don't have threadlock on any part of the motor, but thanks
This is the second time, that I've asked questions on hobbywing, and still no reply, going to try smc motor
Old 07-27-2015, 10:24 PM
  #9635
FastPete's Avatar
Trader Rating: 44 (100%+)
Have to run a SCT Pro with 4 pole.
FastPete is offline
Old 07-28-2015, 04:46 AM
  #9636
DirkW's Avatar
Some people actually run that combination successfully, but Hobbywing does not recommend it. For any 4-pole motor, they recommend to use the SCT Pro only (because that one switches into sensorless mode at higher RPM, while the 3.1 is sensored all the time - and 4 poles apparently don't cooperate very well with sensors at high RPMs).
Yes, I have had issues with the Hobbywing fans as well. Both fans that came with the 3.1 died within minutes of use. Will never use them again on anything. Don't change ESCs just for the fans though - just put a different 25mm fan (Mine runs with a WTF now) with the same connector on. Problems are completely gone so far.
DirkW is offline
Old 07-28-2015, 10:56 AM
  #9637
Sorry if this has been covered guys,but I can't find a for sure answer on this.
I have a xerun 150a 8th scale esc (blue edition),can I use the program box to tune it?
The program box that I have
gearhead79 is offline
Old 07-28-2015, 11:02 AM
  #9638
Carter Flotron's Avatar
Yes sir, those two are compatible
Although, we do reccomend the Multifunction LCD unit simply because of its greater features.
Carter Flotron is offline
Old 07-28-2015, 11:14 AM
  #9639
Wow thank you for quick response!!!!! I will be getting the lcd unit pretty soon,but I just got the thing running so I just wanna get some basics done for now.thank you again!!!!!!!
Old 07-28-2015, 11:21 AM
  #9640
Slapjack's Avatar
am I reading the manual right when it says I should not use the lipo cell auto detect? I should program the actual cell count with the program card? I will most likely be using 5s (for now it will be (1) 2S and (1) 3S pack). And I set the cut off to 3.4v. why do I need to set the cell count? Why doesn't the auto detect work properly?
Slapjack is offline
Old 07-28-2015, 04:33 PM
  #9641
Slotmachine's Avatar
The reason is because if you have a weak cell it will looklike your battery is dead to the sensor, so put it on manual cell count to avoid this potential problem.
Slotmachine is offline
Old 07-29-2015, 11:28 AM
  #9642
Paul has it right. You only really need to set the Lipo cell count on batteries with an odd number of cells, but it doesnt hurt to do it with every type. It simply makes everything more reliable without any weird issues
Old 07-29-2015, 01:42 PM
  #9643
raz14's Avatar
For the Hobbywing Justock Club Spec ESCs, is there any way to gain a finer degree of control over settings? In racing more settings between 5 and 20 would be useful.
e.g. drag brake force is limited to: off/5/10/20/40/60/80/100.
raz14 is offline
Old 07-29-2015, 10:10 PM
  #9644
xyzracer's Avatar
Calibrating my 3.1 stock to my mt4s,why do the instructions say to reverse the trhrottle throw before you calibrate?
xyzracer is offline
Old 07-31-2015, 01:32 AM
  #9645
lewis110's Avatar
Yeah, buy a v3.1 lol
I do believe if you hook the esc up to the pc program there is a "custom" setting so you can better fine tune. I could be wrong on that though. But then you will need to use the pc to do any switching.
lewis110 is offline
