HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD >
Like Tree194Likes
Old 07-01-2015, 05:25 PM
  #9466
Slotmachine's Avatar
Originally Posted by Jvcaniggia
Can the 4000KV Xerun combo setup run effectively on 3s? If so, what is the optimal range of pinion gears? Currently running a Tekno SCT 410 and would like to use both 2s and 3s. thanks
No 4s or 3s on the 4000KV. I think you would hurt the motor.
Slotmachine is offline
Old 07-03-2015, 08:27 PM
  #9467
JAE
Trader Rating: 30 (100%+)
Default Xerun at or under 40mm diameter
My basher DHK Hunter only fits a motor at or under 40-42mm total. Any motors that are under 3000kv that can run 3s of 4s at that size? Thx
JAE is offline
Old 07-04-2015, 06:19 AM
  #9468
MugenDrew's Avatar
Trader Rating: 36 (100%+)
The 4068sd. This has been a fantastic motor for 1/8th buggy.
MugenDrew is offline
Old 07-04-2015, 06:44 AM
  #9469
cjanderson3's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Slotmachine
sounds like a LVC problem. Adjust your Low Voltage Cutoff to 2.8 and try it. When it stops does it have steering still?
That did the trick. Thanks for the advise!!!
cjanderson3 is offline
Old 07-04-2015, 06:46 AM
  #9470
I run the same set up and have never felt the need for a 3s. 2s is more than enough
Old 07-04-2015, 08:08 AM
  #9471
Hi
Just picked up a eb48.2 buggy and it has a sct pro with a 1800 kv motor
(4s lipo)
I'm wondering if the esc is adequate with this setup and would it be a problem if I went to a 2200 kv motor
dk10438 is offline
Old 07-05-2015, 02:46 PM
  #9472
Matt Trimmings's Avatar
Trader Rating: 171 (100%+)
Any feedback on the new V10 1/10 scale motors? Thinking about picking up a couple for a 2wd/4wd buggy. If you cane from a different motor how do you like then compared to your old stuff. Thanks!
Matt Trimmings is offline
Old 07-05-2015, 04:36 PM
  #9473
I've got the sctPro esc paired with the 4700KV motor. I've been thinking of doing the update to my esc. do I hook up my program box and then to my esc to do the update ??? and will I actualy gain anything by doing it ? My esc and program box is almost a yr old and my Motor was bought at Christmas.
thanks in advance Cory
Dirtraycer is offline
Old 07-05-2015, 05:17 PM
  #9474
Tim Garland's Avatar
Originally Posted by Riflebuilder
The box connects and was able to be updated. Just cannot get the ESC to be recognized on any of my computers.
I've found that if you have the esc connected to a spectrum receiver, it will not be recognized. Disconnect the receiver and try again.
Tim Garland is offline
Old 07-05-2015, 06:58 PM
  #9475
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by dk10438
Hi
(4s lipo)
Same setup I use for two years now, and the 2200 is a beast if you like power.
FastPete is offline
Old 07-05-2015, 07:14 PM
  #9476
Carter Flotron's Avatar
I also use this setup. Using the bigger motor allows you to turn it down when you don't need it, unlike the 1800 that feels a little sluggish on long tracks
Carter Flotron is offline
Old 07-05-2015, 08:01 PM
  #9477
Trader Rating: 21 (100%+)
Is there any place that has any ESC set-ups listed? Have been running a Justock and picking up a stock spec 3.1 to try for 17.5 blinky. I saw one listed on 2wd mod from Ron Schuur, but said it was a little different than they usually run.
Brian L is offline
Old 07-05-2015, 08:54 PM
  #9478
Thanks!
New to r/c. Have a couple of scte's with tekin so more familiar with those setups.
1/8 th scale on it's way and getting excited to try it out. Sounds like the sct pro and 1800 kg can is a good combo. Might try to find a t8 but I'm sure this will be more than fine for now!
dk10438 is offline
Old 07-05-2015, 09:37 PM
  #9479
I am running a Xerun stock spec V3.1 ESC with my 4pls in mod buggy. The question I have is what do I need to do to the ESC if anything to get my car to stop? It just wants to coast when I apply the brake and I have been messing with the end points and all of the brake settings on the Xmitter. Any help that anyone has would be great.
dayjef is offline
Old 07-06-2015, 06:15 PM
  #9480
Hessanator's Avatar
http://www.petitrc.com/reglages/hobbywing/SetupSheetsHWXerunV3.html
Hessanator is offline
