HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#5101
some tracks run it as a stock spec class, which would be blinky mode, no timing at all permitted. Others, like mine run it as a 17.5 class. This will allow you to manipulate timing and turbo and such. 17.5 's respond much better to timing than a 8.5 mod motor would. 17.5 is more of a driver class, especially blinky, as you have to have setup and driving dead on to be in the top of the class. (versus mod which is driver and who's got the biggest motor.....sort of)
#5102
On a side note, the V3 series is great. To switch to blinky all you do is set both turbo/boost to 0 and the esc will blink. No more hooking up to the pc program to re flash the firmware. Like turboTim suggested.
#5103
Okay thanks guy's for your help
#5105
#5106
#5108
Yes and No...
In regards to Mod biggest motor win is a bit of a stretch. I have watched many many times where drivers going from 17.5 (stock class) move to mod with a bigger motor and there lap-times actually go up. Putting the power down and keeping it under control with a 8.5 or a 7.5 in a 2wd buggy is much more difficult than running a 17.5.
With that said to win in 17.5 you have to drive like mad and make no mistakes and keep momentum up around all corners. With mod you have to stay in control and put down as much power as the chassis will hook up and not make mistakes.
#5109
Running a 150A xerun ESC and a 1900kv motor (2 x 2s 6.0AH 65C-130C Lipo). Would like to know if I were to run a high voltage servo, would a UBEC be necessary.
Thanks in advance
Thanks in advance
#5111
#5113
I sent back a 150a esc last year in dec and all i have is is the reciept were i fax the the shipped ment is there any way can you guys help get my esc
#5115
. Can someone explain to me about punch on the v3.1 and how it works and why. I don't understand it or how to use it 17.5 motor . and what it does. .? Thanks
