HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#196
...And speaking of seizing control: Yesterday I hooked up a brand-new Xerun 80A to my laptop via the LCD programming box and most of the 'advanced' options weren't visible. I could get Max Rev, Initial Brake, Neutral, and Timing. 'Motor Type' was greyed out, and none of the others (cool stuff like turbo level and timing punch) were even visible. What gives?
#198
hey guys, what are normal esc and motor temps? just tested my new xerun 60A and 17.5T and its quite slow in comparison to other guys? punch is at 6 and timing at 6. current 28/82 on stadium truck. I tried changing spur to 30/76 combo and it helped a littler bit, esc seems very cool, but motor a little warm, just not sure what are safe temps. only problem is now i cant clear the double. thinking of smaller pinion but scared i'll top end mid way through straight = hotter motor? Am i understanding this correctly?
what i'm trying to ask is
1. Does smaller pinion work motor harder or esc
2. how do you figure out optimal spur/ pinion sizing.
3. Does timing affect esc or motor temps
i'm just scared of burning my new stuff.
#199
Hi,
I just received my 150a Xerun with 2200 kv for my Summit today.
I am having problems though and was after some help.
The truck starts running, slooooowly and then just stops. The red led single flashes. From the manual this signals low voltage protection.
Ok here is my setup for reference -
gearing 13/58 (running big canyon tyres for now)
Packs - 14 cell 3000mah NIMH. The traxxas ones that came with the Summit.
I tried running it on the Summit's low range diff and it still does the same thing, I am pretty sure my gearing is ok. From calcs it should give me about 27mph which doesn't seem over-geared.
Not sure if the esc is the problem....... I am hoping somebody will tell me my packs are rubbish and wait for the 4s lipos to arrive.
Thanks in advance for any help.
#200
A smaller pinion (after a certain point) will cause you to be undergeared and will put more strain on the ESC as opposed to a pinion that is too large which will put more strain on the motor, causing more heat there
Your truck should have come with a guide that will give you a ball park, then work up and down from there based on performance and temperature. Another option would be find the thread for your truck and see what others are running
Yes, timing will cause the motor to work harder by squeezing more power out and will typically cause a rise in temerature
#201
Hi,
#202
#203
I also lowered the punch to 4.
#204
Does that ESC support NIMH? You need to change the setting from AUTO LIPO to custom or NIMH. Im drawing a blank on what the available choices are. I'll go look at my program box and get back to you
#205
Seriously- your ESC/motor combo probably places so much of a demand on the batter that at launch the battery voltage sags badly, invoking the LVC. Turn punch all the way down, turn timing all the way down, and no full-throttle launches. Until you're 4S'd.
#206
#207
Your packs are rubbish; wait for the 4S LiPos to arrive.
#208
I placed this question in the 120A thread by mistake, cab anyone help with safe boost and timimg settings for 17.5T?
"Hey guys, I've loaded stock 930 for my xerun 60a and hobbywing 17.5T in my stadium truck(22t)
When you say timing can be 30, which timing is that, 9:boost timing or 12:turbo timing? I'm thinking of leaving it all default settings at first to see how it reacts?
I was looking for something to help clear the doubles at our track. Seems fine on the straight with 82/28 combo.
Thanks ( sorry guys, just realized this is 120a thread, my bad, if anyone has help though, still welcome)
Originally Posted by gogi108 View Post
i'm running 19 pinion 80ish spur in my b4 with 10.5 xerun combo running 930stock . timing can be 30 with boost maybe 10 or so , number 15 maybe start 500 or so , turbo delay off , boost increment i'm using 18deg per .1sec so it comes on hard (wheelstands when hooks up right). i was amazed when i first loaded the boosted firmware into the speedy , doubles the power
Thanks for all your help guys, I'll hold-off until my packs arrive. Hopefully once I have these the car will run properly.
#210
Ok tell me if Im wrong. I bought the 150a 1/8 esc thinking that it will work with my SCTE and today I tried to get it running. I had programmed the esc and followed the directions.
I couldnt get my scte to run with out any hesitation. So to my conclusion I figured that the esc is not set up for scte but 1/8 buggy/ monster/ crawler vehicles.
I ordered a sct pro. Ill just have to order a 1/8 motor for my buggy then. lol
