HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#1696
Honestly I have never ran the 1800 so I wouldn't know. I run a 2250 and just adjust endpoints as needed. That said, gear up.
#1698
I would say, go for the 4068 motor type (40mm diameter x 68mm length) because the 4274 will not fit I believe, because the length of that one is 74mm.
#1699
#1700
i could be wrong but i think a standard size motor would fit. here is the kit that i have.http://www.rc-monster.com/proddetail.php?prod=rcm811
Then Yes, a bigger motor would fit.
You are going to run on 4S lipo?
The 1800KV or 2200KV doesn't really matter, if you need more speed, just gear up a bit, any of those 2 motors will handle it.
#1701
Aha, you have a non Serpent conversion kit (do we even have a conversion kit? hahaha, I don't even know..... hahaha).
#1702
My combo didnt come with the disk for the software is that an issue? Can i get it off the website?
#1703
http://www.falconsekido.com/pages/download
Got my Xerun 150 wet when I cleaned the truck and ruined the thing. Replacing it with an SCT-Pro which will be better for my setup anyway... blessing in disguise I guess...
#1704
#1705
#1706
Well I got my RC8.2e built and installed my HW SCT Pro ESC and 1800kv 4274SD motor. I'm honestly quite underwhelmed coming from my Castle MMM + 2250kv setup. On 4S the setup seems really lacking on the top on, and even feels pretty weak on torque. I'm running an 18t pinion on the stock 46t spur gear. The ESC is set on all factory settings, and I'm running it sensored.
Any advice on how to get this thing to wake up? I'm thinking it could partially be because of my battery, so I ordered a new 5700mah 50c battery to try. I'm also wondering if I shouldn't go up to a 20t or even higher pinion gear.
Other than that, I'm at a loss. I hear great things about these motors and ESC's and right now I'm feeling pretty "blah" about it.
#1707
#1708
I understand and I definitely appreciate the help. I actually switched away from the Castle because the power delivery was too on/off and I didn't like it. I wanted something smoother and the HW combo CERTAINLY is that. I love the way it feels with the linear power, just looking to get a little bit more out of it.
#1709
I accidentally upgraded my firmware to v3 on my esc and programmer (didn't read the fine print). I'm guessing I'll be ordering new ones?
