Speed Passion Thread
#571
I just ordered 2 of these motors : Silver Arrow V2.0 Brushless Motor - 5.5R
But I can not find a lot of specs,
does these motors have fixed timing? or adjustable? if not what fixed timing do they have?
#572
Looking for a suggested setup for my LPF.. I have not been on hear in a long while..
Could i get a suggested setup for the following?
-Tight indoor carpet track
-med/high grip
-short straight 60ft ish
-2wd buggy
-13.5 motor
-323 software (v1.37 interface)
-Track laps around 12-14 seconds.
Look for good low end grunt. top end not needed. Currently have no temperature issue.
thanks
-med/high grip
-2wd buggy
-13.5 motor
thanks
I'd try something similar to my 17.5 setup on the website.
Basically try gearing around 19/84-23/84.
Drag Brake - 5 to 15% - personal preference
other "key" settings
DRRS - 9
Boost timing 40-50 (try more later)
Turbo timing (top end related but set to around 20-30)
Set the last setting to 100 and check temps. If hot, go UP on this setting to 150 or 200 and add more boost and turbo timing. If cool go down to 50 and get more speed yet.
that's off the top of my head but if you go to the website and check the stock buggy setup sheet you should have a lot of close settings to that to start out.
#574
#576
#577
#579
Hey Solara,
SO I got a SP GT2.1 w/fan and a Tekin 550 5.5 for my SC104x4. Whats the recommended setup? I saw the Team Drivers pdf's and there is one in there for the 5.5 in a SCTE Losi. Is that a good starter? What you thinking? I have the LCD programmer so I'm good there.
#580
DRRS - 9
DRRS - 9
#581
initial brake is set to drag....then its 15% of 50
ive been setting my lcd to 100% brake then take the epa down till it just locks the tires
initial brake is at 0
mayor get my number from sassy if you ever have questions
#583
What class? You really don't want to run anything hotter than 10.5 due to the timing software that is included with the speedo. You can always reflash it (205 mod) to run hotter mod motors, but keep in mind you will also need the LCD card to do so.
#584
Well, ran the SP GT2.1 with Tekin 5.5 550 can in my sc10 4x4 last week with great success. Finished 10min main in 3rd outta 11 trucks and the ESC ran flawlessly all night. Geared at 62/14 32p gears. Temp on esc was about 112-120ish and motor about 140ish. Ran at zero boost. 110323stock spec too. I can add boost but it was fast already.
#585
Now...go clean up your car especially that good looking ESC....
4Likes
