Speed Passion Thread >
Like Tree4Likes
Old 08-30-2011 | 09:04 AM
  #496
Originally Posted by kstoracing1
Yeah, I like my 2.1 over my MMP. I would like to compare the R10 though.
Like DAVID said...use the posted setup from our site....EX works really good with 2WD buggy because of the low heatsink design...and works great with 323stock boost software..or no timing.
GT2.1 PS works out great on 4WD...I think Mike K used it for 4WD or 2WD or SCT but it will work with all the software from our site.
Solara is offline
Old 08-30-2011 | 09:26 AM
  #497
+1. That's why I run the GT 2.0 LPF in my B4, fits under the body nicely. I suspect you'll need a low profile for the 22 as well. 2wd simply doesn't produce enough heat to need a fan, even down here.
cjtamu is offline
Old 08-30-2011 | 09:29 AM
  #498
sc10rr's Avatar
how are the 1/8 setups? any issues etc? i was looking at the Speed Passion Silver Arrow V2.0 1/8th Scale Brushless ESC/Motor Combo (2200kV) mostly because the price is right! i see they have it wired for 2 2s batteries, but can you just wire the esc for one 4s battery?
sc10rr is offline
Old 08-30-2011 | 09:49 AM
  #499
2 2S = 1 4S...voltage are voltage. However, you just have to cut the double plugs and solder the ESC input to 1 single plug...SA2 will work and that combo works great on 4S.
Solara is offline
Old 08-30-2011 | 09:50 AM
  #500
mjk1210's Avatar
Just for fun I put a fan on the standard lpf speedo in the 22 to see if it would fit. As long as the wires didn't run over the fan to the front of the buggy it had plenty of room. In case anyone was wondering. But you're correct, it's rare that a 2wd buggy will need a fan on the ESC.
mjk1210 is offline
Old 08-30-2011 | 01:14 PM
  #501
Thanks for the information.
So which is the best SPassion ESC to use in the 4wd what are the big boys running in them as I'm not sure myself tbh which model will be good or just go for the
SPEXT98802SCB Speed Passion GT V2.1 Brushless ESC Pro Stock Edition
Hope for the best?
carlin is offline
Old 08-30-2011 | 01:32 PM
  #502
4wd what? Buggy or SC?
cjtamu is offline
Old 08-30-2011 | 01:39 PM
  #503
Buggy all the way 4wd
carlin is offline
Old 08-30-2011 | 02:01 PM
  #504
I use a GT 2.0 Pro with a SP V3 8.5 in my XX4WE. You can use the 2.1 Pro down to a 5.0t motor.
kwiksi is offline
Old 08-30-2011 | 02:10 PM
  #505
I currently have the LP 2.1 in my 22 running an 8.5. No complaints. Looking to get another for my future 22t and might to replace the MMP in my B44.
Probably will save the dough and buy a second or a motor. LOL
kstoracing1 is offline
Old 08-30-2011 | 03:53 PM
  #506
mjk1210's Avatar
I use the same (gt2.0 pro) with a v3 7.5. Never had any issues with it in the b44.
mjk1210 is offline
Old 08-30-2011 | 04:22 PM
  #507
mjk1210
You going to the ROAR region 5 race at Proving Grounds?
kwiksi is offline
Old 08-30-2011 | 05:25 PM
  #508
Slash'em1's Avatar
Slash'em1 is offline
Old 08-30-2011 | 05:27 PM
  #509
ilanstylz's Avatar
This is a shot in the dark, does anyone have or know where I can get the user manual for the Speed Passion GT V1.1?? The sp gt 2.0 are out of stock so I picked up the older version in a trade for now but there were no instructions for the esc and I can't find it anywhere online........
ilanstylz is offline
Old 08-30-2011 | 06:40 PM
  #510
GT 2.0 Pro with a 6.5 in my B44. Had it about 6 months, flawless. 205 Mod firmware.
cjtamu is offline
