Like Tree4Likes
Viper RC -
Old 11-06-2014 | 04:34 PM
  #11026
Motorman007's Avatar
What settings do i need to use to get my motor to free roll?
When i get off the gas the car just stops way to hard for me. It want roll.. its like i have the brake on all the time.
Thanx
Motorman007 is offline
Old 11-06-2014 | 05:15 PM
  #11027
bdyche's Avatar
Thanx
Double check a few mechanical things first. Remove your pinion and try to roll the rear wheels. If it doesn't roll, your problem is not an ESC setting, it is most likely axle spacing, bad hub bearings or a bad bearing in the transmission. If it does roll, double check that your gear mesh isn't too tight. If all of that checks out, check for drag brake. Set it to 0 and increase it as you feel that you need.
EDIT:
Also double check your throttle trim. Set your throttle and brake EPA to 100 and your throttle trim to 0, then recalibrate the ESC to the radio.
bdyche is offline
Old 11-06-2014 | 06:11 PM
  #11028
EDIT:
I will do all this sir.
Thank you
Old 11-06-2014 | 09:18 PM
  #11029
nikos2002's Avatar
As Brandon said - always check the mechanical side to make sure you don't have a bad bearing or something bent.
On the speedo, Drag Brake settings and proper calibration should be checked.
Finally - on the motor itself. With the motor out of the car, spin it. Should spin free, if it has resistence, there could be a short internally. Although 2 pole motors once that happens they should stop running (4 pole different story).
nikos2002 is offline
Old 11-06-2014 | 09:20 PM
  #11030
nikos2002's Avatar
Originally Posted by segreda
Hi guys
Do you know the bearing size of the vf8 line???
Pretty sure I answered your question via Facebook but just in case, we got 5mm x 13mm x 4mm for that bottom bearing. Top is standard brushless motor bearing.
Old 11-07-2014 | 04:07 PM
  #11031
Default calibration??
Its been a while since I calibrated my vtx10. If I remember correctly, it was different than whats indicated in the instructions?? Not sure, but if anyone has any info regarding calibration, that would be great. Thanks.
rage1945 is offline
Old 11-07-2014 | 08:36 PM
  #11032
bdyche's Avatar
1. Connect a proper/charged battery pack to the ESC.
2. Turn on the transmitter with the throttle endpoint
adjustments at 100% and all throttle trims centered.
3. Press and hold the red power button on the V-PORT for three seconds (Followed by beep tone, F/N LED on the V- PORT will be indicated as the image at right)
4. Pull full throttle and hold, while holding press the red power
button once. (Followed by beep tone, N/R LED will be indicated
as the image shown at right.)
5. Push full brake and hold, while holding press the red power
button once. (Followed by beep tone, all LED’s will cycle.)
6. Calibration completed!
Straight from the Viper VTX10 manual, same way I do mine every time.
bdyche is offline
Old 11-08-2014 | 12:31 PM
  #11033
Thanks for the reply. My instuctions are different than that. Mine must be really old!! Lol. I'll give it a try. Also, I have an M12 and the steering, throttle and brake go to 150%? Should I calibrate both at 150% or 100% like it suggests in the viper instructions? Not sure?? Thanks.
rage1945 is offline
Old 11-08-2014 | 12:38 PM
  #11034
Default pro gauge or Ez link
I have a progauge and was wondering what the difference between this and the (newer?) EZLink is? Thanks
rage1945 is offline
Old 11-08-2014 | 02:13 PM
  #11035
GRIMREAPER's Avatar
What viper 1/8 system would u recommend for a losi 8ightt 2.0 and rc8
GRIMREAPER is offline
Old 11-08-2014 | 06:25 PM
  #11036
Are you meaning system? If so vtx8 with 1900kv is the wy to go.
urluzn is offline
Old 11-08-2014 | 06:28 PM
  #11037
GRIMREAPER's Avatar
1900kv for the truggy too i dont race looking for the most power
Old 11-08-2014 | 06:52 PM
  #11038
Didn't see the T. 2100kv will be more than enough!
urluzn is offline
Old 11-08-2014 | 08:03 PM
  #11039
GRIMREAPER's Avatar
ok cool how would you compare the viper systems to tekin or castle thats all i ever ran
Old 11-08-2014 | 08:12 PM
  #11040
I've only run viper 1/8. From what I'm told by guys that have run others its a whole lot smoother.
urluzn is offline
