Like Tree4Likes
Viper RC -
Old 06-25-2014 | 04:01 PM
  #10696
nikos2002's Avatar
Originally Posted by Motorman007
I read everything I could on this and still will not get the green light when I try to calibrate. Everything seems work.
Pullback hit the button
Push forward hit button
Let go all lights do its thing
Green like flashing after
I also hooked up other motor
And other sensor wire.
I flashed the A64, many times.
Radio 10 clicks - /+
Anymore ideas.
Before I send it in?
Then I did the same thing to my tekno truck same 1/8 esc vtx8 and it calibrate.
-Try different model on your radio?
-Try same model you calibrated your tekno on?
You can always send it in, just hate when someone sends something in and we can't find anything wrong with it. Just trying to make sure.
nikos2002 is offline
Old 06-25-2014 | 04:02 PM
  #10697
nikos2002's Avatar
Originally Posted by boborc
Also whats the ETA in the VF4's I see their out of stock. See what happens when I snooze. should have gotten one a couple of weeks ago
Maybe you should see if the backorders are open on the shop site
Old 06-25-2014 | 04:04 PM
  #10698
nikos2002's Avatar
Originally Posted by carguy83
I think I'm going to leave my stock setup alone and work on my driving skills.
That is the biggest way to shave down your lap times -- just drive!!
Old 06-25-2014 | 04:06 PM
  #10699
nikos2002's Avatar
Thinking of getting a vf4 for a sc10 4x4. What rpm/kv do you recommend 4k 0r 4500. Med-large tracks. Have a 4.5 ballistic which is good but need a little more launch. Have a budget 4 pole 4800kv seemed a little overkill on the med track and is also undependable (shabby bearings keep going). The ballistic is rated 5k per kv so should I go with the higher or just a little more gear in the lower kv (slippery tracks for the most part). The large track has a 3/4 oval for the straightaway (its big). Thanks
4500 is your using the word big to describe the track. 4000 would be more for smaller indoor tracks.
Old 06-25-2014 | 04:50 PM
  #10700
boborc's Avatar
It was letting me backorder if I wanted. I'll place an order for a 4500 tomorrow. Have some home projects this weekend so no racing for me anyway Hopefully next week
boborc is offline
Old 06-25-2014 | 05:03 PM
  #10701
nikos2002's Avatar
He's a man with a plan!!
Old 06-25-2014 | 05:55 PM
  #10702
Motorman007's Avatar
I did that sir nothing.
This I have not tried
Will do it now thank you sir.
HERE IS THE VIDEO I JUST DID
+ YouTube Video
Motorman007 is offline
Old 06-26-2014 | 03:48 AM
  #10703
boborc's Avatar
Order Placed
boborc is offline
Old 06-29-2014 | 04:35 AM
  #10704
I have been running a 4500 copperhead combo in my ten scte and seems I can not keep my temps down I am currently running a 15 tooth pinion with stock spur and yesterday after the 6 min main my motor temps where reading 185! I really don't want to drop pinion size again. But I am really taxing this motor, I have had esc overheat kick in twice before dropping my pinion down. This is the second motor as a warranty replacement . I never had these issues prior to that could this motor be less efficient ? Or will I need to move up to the vf4/vtx8 to get decent run times? Thanks
ennis437 is offline
Old 06-29-2014 | 04:49 AM
  #10705
I should also mention that both esc overheats happened after a crash, unread somewhere in the forums that an arc from the bullet connectors could cause the system to read esc overheat , is this the case ? Also would any of the new high voltage fans run better on my esc? Mine will sometimes hang up durring start up.
ennis437 is offline
Old 06-29-2014 | 05:18 AM
  #10706
DustinH's Avatar
Where are your settings at? Like punch, start power and timing? I usually never run any of these over 5.
DustinH is offline
Old 06-29-2014 | 05:35 AM
  #10707
bds81175's Avatar
Moderator
Also, what type of track and how big? A 15 tooth for an SCTE would imply a pretty big track. I don't ever gear to a 15 with my SCTE.
bds81175 is offline
Old 06-29-2014 | 06:48 AM
  #10708
Evo X Revo's Avatar
Just picked up a vtx8 for my sct410. Trying to figure out if I need the PC link for anything other than updating the firmware on the esc. I have the progauge and hoping I can get to all the settings. My friend has the link so figuring I could just use his for updating. Thx for any info.
Evo X Revo is offline
Old 06-29-2014 | 07:31 AM
  #10709
bds81175's Avatar
Moderator
Yup, you don't really need the link for anything other than updating unless you want to be able to save out and/or update setups to your computer. Having a buddy with one of these is NICE....
bds81175 is offline
Old 06-29-2014 | 08:05 AM
  #10710
I was running profile 5 but when I got an ez link I lowers timing and punch to 5
ennis437 is offline
