Like Tree4Likes
Viper RC -
Old 10-22-2013 | 05:01 PM
  #9196
AndrewTom's Avatar
Originally Posted by spider882009
Ran the Copperhead w/5150KV at LCRC this past weekend!!! Was smooth, but miss my VTX8 - 4.5 Combo!!! Had fun!!!
Quick question? What viper 1/10 esc is capable of running a 6.5 or 7.5?
vtx10 will run down to a 7.5t, 540 can motors only.
vtx10R will run down to 2.5t 540 can motors, and run some 550 motors as well.
AndrewTom is offline
Old 10-22-2013 | 05:58 PM
  #9197
nikos2002's Avatar
/\/\/\/\ what he said /\/\/\/\/\ - ok that didn't work, didn't know it was pushing to another page.
Chad your VTX8 replacement is sitting on the shipping table, should go out tomorrow.
nikos2002 is offline
Old 10-23-2013 | 07:38 AM
  #9198
spider882009's Avatar
Thumbs up Thank You!!!
Awesome I have all VTX10's and my lowest motor is a 540 can 7.5!!!
Awesome Nick!!!
spider882009 is offline
Old 10-25-2013 | 08:35 AM
  #9199
slashman404's Avatar
Default set up help
I apologize if this has been addressed a long time ago but I recently switched to a VIPER VTX10BE in my SC10. I am running at this weekends Shortcourse Showdown and have zero setup time with this so need a base to start with for the 2wd Stock class 17.5 Blinky. What do you suggest for parameters for the esc. Do you have any setup sheets? Thanks.
slashman404 is offline
Old 10-25-2013 | 09:02 AM
  #9200
Profile 1 should be a good start.
I ran a brand new SC with a 13.5 w/ the blinky profile 1 and threw it on the track and just drove.
Barge is offline
Old 10-25-2013 | 09:15 AM
  #9201
Jim Hustins's Avatar
Here is my blinky setup.
Throttle PWM 4000
Throttle punch 100%
Throttle curve linear
Forward power 100%
Brake PWM 2000
Brake 100%
Drag brake 20%
Brake curve linear
Jim Hustins is offline
Old 10-25-2013 | 09:37 AM
  #9202
nikos2002's Avatar
slashman - looks like they have some answers for you there.....
Also David Fast is one of our Team Drivers he is there this weekend as a representative for us. If you can't find him, ask Scotty or Dave Duncan from J Concepts to point him out to you. David will be able to help you more and answer any questions.
But I would start with Jim's set up!!!
Old 10-25-2013 | 09:47 AM
  #9203
Default Thanks
Thanks!!!!!!!!!
Cory
Old 10-25-2013 | 09:57 AM
  #9204
Kevin_M's Avatar
Nick I recieved my VTX8 today in the mail. I got email saying the motors are going to be in at end of Nov. Do you have a firm date yet?
Kevin_M is offline
Old 10-25-2013 | 11:07 AM
  #9205
nikos2002's Avatar
Honestly, I would like to say xxxx weeks, but I would rather wait until they actually shipped to us before I say, only because I don't want to get hopes up until I know its coming. We have actually upped our initial thoughts on first production, because we want to have enough for everyone.
Old 10-26-2013 | 05:35 AM
  #9206
What does changing the throttle and break frequency do?
I am going run my vtx8 tonight for the 1st time and wanting to know what it is supposed to do if I change it
micrors4guy is offline
Old 10-26-2013 | 05:59 AM
  #9207
It changes the feel of how the throttle or the brake come on. The lower the # the harder it hits, the higher the # the smoother it will be.
In 17.5 Short Course, I lower the Brake PWM to help it come on harder to adjust the truck in the air. This will change the initial feel, but not the overall level of braking. I also lowered the Throttle PWM to make the 17.5 motor more punchy since adding timing is not allowed. It does not add power or any boost, it just helps it ramp up faster.
With a VTX8, I assume you are either running it in an 1:8 buggy or in a 4wd SC truck and a powerful motor. I would keep the Brake PWM the same, and you might want to raise the Throttle PWM to 12000 from the normal 9600 setting to help smooth out the power delivery.
Old 10-26-2013 | 09:05 AM
  #9208
Thank you that is exactly what I was looking for in an explanation.
Here is the ride ready for battle.
Old 10-26-2013 | 02:25 PM
  #9209
Kevin_M's Avatar
Nick I am wondering if and when I need to update my esc firmware.
How and where do I do it?
Is there a way I can get a copy of the esc manual sheet blown up (maybe online some where)? Its hard to read small writing.
Kevin_M is offline
Old 10-26-2013 | 02:46 PM
  #9210
Cain's Avatar
Tech Legend
One thing I would like you to consider nick in the future as a software update (if possible) is if you are trying to shut down the ESC, regardless if signals or what is perceived as signals are coming in from the radio, you can still shut down the ESC.
I know with my Futaba 4PL, if there is any perceived signals, the ESC will not shut down so I have to basically turn the radio off. To me at least, I can't think of a situation where if I am trying to shutdown the ESC directly that the ESC needs to prevent that from happening if it gets a signal from the radio.
Cain is offline
