Like Tree4Likes
Viper RC -
Old 03-30-2011 | 12:29 PM
  #976
Trevor Williams's Avatar
R/C Tech Elite Member
sup JD!
my DX3R is fine.....but I did have to use a external cap for my spektrum 6040.....that was prior to me getting on the team when I ran a Tekin RS.....as for right now, Im not running, my car will be in tomorrow and the new esc/motor a.s.a.p
Trevor Williams is offline
Old 03-30-2011 | 12:48 PM
  #977
Between, Vipers new esc and Xfactorys new 4wheel buggy im going crazy. Bad thing is I have a proto esc. I know how good my other 2 cars could be!!!
SikKustomz is offline
Old 03-30-2011 | 12:53 PM
  #978
what up Lendel!
hope all is going well bro!
Old 03-30-2011 | 01:04 PM
  #979
Back at ya! well see ya soon at BnL??
Old 03-30-2011 | 01:31 PM
  #980
mini-dub's Avatar
Originally Posted by Banshee8530
5Amps sounds good to me too. With the adjustable BEC, that's just voltage right? Tell me if I'm right about this: increasing the BEC voltage will necessarily increase the amp draw of a given servo.
The BEC voltage is adjustable in 0.1v increments from 5.0-7.0v. Changing the voltage will change the servo amp draw, higher voltage=lower current draw, lower voltage=higher current draw.
Originally Posted by jurquhart
Has anyone tried the new Viper motor with the MMP. I tried it and I'm experiencing a lot of cogging. Change the motor and it goes away. Try a different Viper motor and same thing more cogging. Can't figure out if it's just a software conflict with the MMP
Sorry we haven't been able to sort out the cogging issues with your MMP yet John. After inspecting your motor and having it check out perfectly I reached out to all my drivers to see if any of them may be able to help us with the MMP settings. I know we have had drivers testing the VSE 1/8 motors on the MMP with good results, and that uses the same sensor unit.
One thing I noticed was that you were using small gauge wire, either 16 or 14ga, it looked like 16ga to me. I suppose this small of wire in a heavy truck with a modified motor could pose problems. Also please make sure there is ZERO timing added in the esc settings. We may try reducing the end cap timing as well. Thanks for your patience while we sort out this unusual problem
mini-dub is offline
Old 03-30-2011 | 01:50 PM
  #981
SO When will we know the pricing and actual release date for the 1/10 esc's just waiting to see how competitive the pricing is before I make a decison between this and a Tekin.
Or has anyone reviewed them yet?
Maynard is offline
Old 03-30-2011 | 02:00 PM
  #982
bigfred819's Avatar
Is there going to be a 3 piece combo? Motor, esc, pro-gauge. When? Need to pull the trigger on something here pretty quick.
bigfred819 is offline
Old 03-30-2011 | 02:05 PM
  #983
sixramsalot's Avatar
so these motors work good with a novak havac pro without issue
sixramsalot is offline
Old 03-30-2011 | 02:15 PM
  #984
smokinu's Avatar
just so you know.. The pro gauge is included with the esc.
So a Combo would actually be a 3 piece.
smokinu is online now
Old 03-30-2011 | 02:16 PM
  #985
smokinu's Avatar
yes, Main Problems are coming from the MMP esc.
What motor dose not have problems on that esc though?
Old 03-30-2011 | 02:19 PM
  #986
I would love to make it down this summer for some 1/8 gas buggy and 1/10 electric 2wheeler
Old 03-30-2011 | 02:22 PM
  #987
mini-dub's Avatar
You have a PM The first shipment of VTX10 and VTX10R's will arrive mid April.
The first shipment will have both the esc/ProGauge combos and the esc 'lite' version without the ProGauge. We will have motor/esc/ProGauge combos available several weeks after the initial shipment of escs.
There is an industry standard for sensor compatibility and design which is why sensor wires work across any esc/motor combination. There should be no problem using the VST motors on any Novak esc's. Any compatibility issues people have experienced with the VST motors and other brand esc's are likely due to a setting error or some issue with that particular esc. I do not have personal experience with the Havoc Pro however, so hopefully someone can chime in and give you a more concrete answer.
mini-dub is offline
Old 03-30-2011 | 02:58 PM
  #988
Dlewis4's Avatar
Just wanted to show off my Viper powered ECO...
This will be the only Viper powered vehicle I run during the outdoor season... unless I pick up a 4x4SC
Dlewis4 is offline
Old 03-30-2011 | 03:23 PM
  #989
hlb14's Avatar
no naked pics
hlb14 is offline
Old 03-30-2011 | 03:26 PM
  #990
Dlewis4's Avatar
Originally Posted by hlb14
no naked pics
Nope
Dlewis4 is offline
