Like Tree4Likes
Viper RC -
Old 01-12-2013 | 07:58 PM
  #6571
nikos2002's Avatar
Bobby Z- have you tried a different motor? Does the vport show you that the lights are reading full power and full break.
Meyankee- yes if that green light keeps blinking it means the esc can not find neutral from the radio.
nikos2002 is offline
Old 01-12-2013 | 08:03 PM
  #6572
Anyone have some good default race settings for a viper vtx10 with vst8.5 setup? Going to trying it out for the first time tomorrow just have it on practice mode right now. I added some drag brake and have throttle punch at 75% for practice tomorrow. This is in a sc10 with 20/84 gearing.
JJay03 is offline
Old 01-12-2013 | 08:25 PM
  #6573
Bobby Z's Avatar
Yes I tried another motor and the original motor works with another speedo I took out of my truck. The lights appeared to be working normally. I'm going to try calibrating the unit to my radio again and will report back
Bobby Z is offline
Old 01-13-2013 | 05:31 AM
  #6574
nikos2002's Avatar
Bobby- if the lights are working correctly - you get a solid green light at full throttle and a solid red at full brake, its a connection issue somewhere. Cold solder joint? Bad sensor connection or wire?
JJay - seems like a good starting point. I think I ran 22/87, but I am away from my computer this weekend.
Old 01-13-2013 | 05:37 AM
  #6575
DustinH's Avatar
I run 17/87 gearing in mine, but should probably bump up some. I've got a setup I can email you.
DustinH is offline
Old 01-13-2013 | 08:02 AM
  #6576
Thanks PM sent.
JJay03 is offline
Old 01-13-2013 | 09:30 AM
  #6577
Mxer59's Avatar
Will the Vse-B for 1/8 be out anytime soon? Would like to pair a vtx8 and motor together
Mxer59 is offline
Old 01-13-2013 | 02:06 PM
  #6578
bigjerry's Avatar
Does it matter on the direction of wires of the motor
bigjerry is offline
Old 01-13-2013 | 02:14 PM
  #6579
Wildcat1971's Avatar
Order maters in sensoref
Wildcat1971 is offline
Old 01-13-2013 | 02:22 PM
  #6580
bigjerry's Avatar
vx4 copperhead 3 leads out the motor is there a correct way to connect
bigjerry is offline
Old 01-13-2013 | 02:25 PM
  #6581
tobamiester's Avatar
For uncensored I don't think it matters.
tobamiester is offline
Old 01-13-2013 | 02:29 PM
  #6582
Copper is sensorless. You can hook it up so the motor is reversed. No biggie just swap 2 wires.
Old 01-13-2013 | 03:29 PM
  #6583
Drove it on the track today for the first time the power was really good I liked it . My motor was 170 degrees is that too hot? Im geared 20/87 in a sc10 with no added timing.
JJay03 is offline
Old 01-13-2013 | 03:42 PM
  #6584
bigjerry's Avatar
Is there a way to defalt the esc to factory settings with out pro guage
bigjerry is offline
Old 01-13-2013 | 03:51 PM
  #6585
I'd love to know the answer to that. Seems like I read in the forum that "reflashing" the firmware would reset everything back to default.
shagnat is offline
