Like Tree4Likes
Viper RC -
Old 12-10-2011 | 11:33 AM
  #3301
Rdog's Avatar
Hey Guys Im new to Viper and I seem to be having a problem with my Pro Guage and or Speedo. Its a vtx10 I plug in the pro guage and go to link device and it comes back with a "connection failed" Im not sure if it the guage or the speedo or me thats maybe not doing somthing correctly? I was wondering if maybe you guys had some advice or maybe simular issues? Or do I need to send it in to Viper to get taken care of? Thanks in advacne guys.
Rdog is offline
Old 12-10-2011 | 11:37 AM
  #3302
rider313's Avatar
With the speed controle on are you pressing and holding the power button for 1 second. Then the orange and red lights will light up solid. Then you link the pro-gauge.
If you make changes be sure to save them and then press the power button for another second to return to run mode.
rider313 is offline
  #3303
when the esc is on press and hold for about a second till you see the lights i turn red/orange at the same time then plug the pro gauge on and link it..when done setting it up save it then unplug the pro gauge then push the button for a sec till it goes back to normal light use cold be blinky mode or the stock light mode..
ohhhwee is offline
Old 12-10-2011 | 11:38 AM
  #3304
you beat me by a sec man
ohhhwee is offline
Old 12-10-2011 | 08:40 PM
  #3305
ChefDementia's Avatar
I got a new 17.5 VST, its about three weeks old and got to use it for the first time tonight. All through practice it ran great, then qualifying rolls around and there was no go. I did a quick run down the straight, and all was good. Get to work on a couple warm up laps and I could hear it cogging off the line. So I check the sensor wire, it's fine, blip the throttle all is good again, put it down drive to the end of the straight very little power and really slow. I changed the sensor wire, still does it. I'm running a TLR 22, Tekin RS pro, Promatch 60c 4000mah packs. I ended up putting my Orion 13.5 back in and all was well. Any ideas on what went wrong?
ChefDementia is offline
Old 12-10-2011 | 08:58 PM
  #3306
rider313's Avatar
Sounds like a possible loose wire to the motor. When you hold it the car is still and when you drive it the wires wiggle around. When you soldered up the 13.5 did you notice a possible loose wire?
rider313 is offline
Old 12-10-2011 | 09:32 PM
  #3307
Checked that too, all the wires were good and tight.
Old 12-10-2011 | 09:45 PM
  #3308
might have a bad sensored board?
bring it on is offline
Old 12-11-2011 | 05:55 AM
  #3309
rob martin's Avatar
Thumbs up
Here my weekend results. Running viper i was able to tq and take the win in 2wd mod yesterday... Running a vtx10/8.5 combo in my 22 it was smooth all day long
[IMG] Uploaded with ImageShack.us[/IMG]
rob martin is offline
Old 12-11-2011 | 06:39 AM
  #3310
idrummerboy13's Avatar
Default NICE
nice ride rob and nice on the win for mod.
Today I will try to run my 13.5 and attempt to make it run hotter geared 27 75 with stock timing it is just as fast as the novak but more bottem end torque with better breaks and it comes off 30 degrees coolor!
I would like to try to get it with a tad more top end so I get the full use of the viper. 30 75? ALSO what is the recommended heat after a main 6min. 150 i gues..
idrummerboy13 is offline
Old 12-11-2011 | 09:38 AM
  #3311
Great Job
Old 12-11-2011 | 10:13 AM
  #3312
nikos2002's Avatar
Guy - PM me with your email or cell number. I have a set up you can try. It's the one I ran when I was with you that Friday nite. And I was only using a 17.5 so the 13.5 will pull some good top end with it.
nikos2002 is offline
Old 12-11-2011 | 10:15 AM
  #3313
nikos2002's Avatar
Congrats Rob. Does DG paint your bodies also?
Old 12-11-2011 | 09:50 PM
  #3314
brent701's Avatar
I got to play with a Viper system today in a friends truck
He was unable to solder the wires in. So he brought it over for me to.
I gotta say I like it.
The ESC looks very clean. I like the look of the motor and the timing marks.
Get it up and running and man that thing is smooth. played with profile 1 than went to profile 3. You can heat the boost kick in. was cool to hear.
Than played with boost start and end time. That 13.5T makes that SC10 FT kit fly down the street.
Gearing was 20/84 outside temp was about 60 after 2 mins ESC was 78deg Motor was 85 ish. Will know better temp results wed night for it's 1st race at a track we do to.
Only thing I wish was in the manual. Unless I missed it was all the feature on the progauge and how to use them or how they are used.
PPM, RPM. etc etc
I will be ordering a few of these for all my trucks and buggies.
brent701 is offline
Old 12-11-2011 | 10:42 PM
  #3315
Again my viper powered sc truck ran great. Qual'ed 2nd and took 3rd
+ YouTube Video
