Like Tree4Likes
Viper RC -
Old 09-05-2011 | 11:16 AM
  #2536
Originally Posted by Stealth_RT
So, no one knows what the flashing N and R LED fault code means?
Eric Im checking into it for you now.
Poptartninja is offline
Old 09-05-2011 | 11:33 AM
  #2537
Eric give me a call.
Old 09-05-2011 | 03:51 PM
  #2538
Again my Viper powered Kyosho sc ran great.
+ YouTube Video
bring it on is offline
Old 09-05-2011 | 06:27 PM
  #2539
porkchop's Avatar
what rotor comes in the 7.5 and what does each one do for the motor
porkchop is offline
Old 09-05-2011 | 09:03 PM
  #2540
zanernator's Avatar
Reagan or Weylin
i need a motor for 1/12 at the hangar what rotor do you guys recommend for 1s racing? Also a 17.5 for tc and what rotor?
Thanks Guys, Zane C.
zanernator is offline
Old 09-06-2011 | 06:55 AM
  #2541
nikos2002's Avatar
12.5mm is what comes with a 7.5.
I have always been told larger rotor is more torque, smaller is more rpm. In basic terms.
nikos2002 is offline
Old 09-06-2011 | 08:41 AM
  #2542
Tekin Prez's Avatar
Team Tekin
I will not address anything except what I came here for. I know better than to come into your clubhouse and get all ruffled and scared. I do not belong here explaining the RX8 fet count and why it can handle considerably more power.
A Viper employee made a false claim and called out Tekin by name. If some of you would rather be mislead and lied to and even defend their actions that is entirely up to you. When someone is misleading the public about a Tekin product or trying to elevate their product with a false comparison, it will not be allowed.
Originally Posted by SaladFork
I am a Viper employee. My comment about the RX8 was comparing a 1/10th ESC against a 1/8th scale ESC in terms of foot print, FET's and heat dispersion. I was not saying the RX8 is bad, I just said it has almost double the FETs which is true.
It is NOT true and if you continue to claim it officially as a Viper employee we are going to have a problem. The 10R DOES NOT have almost double the fets of a Rx8, not even close.
I am happy to discuss the Rx8 and how it compares in other places where I do belong. Considering how similar the 10R is to our 3yr old original RSpro that also has 48fets we are very familiar with the performance abilities of the platform.
Tekin Prez
Tekin Prez is offline
Old 09-06-2011 | 12:02 PM
  #2543
rcgod's Avatar
Just picked up a vtx10r to use in my 4x4 sc truck. Do you guys recommend using a fan on it? I will be running the tekin pro4 4600 motor. Thanks.
rcgod is offline
Old 09-06-2011 | 12:16 PM
  #2544
jsamarin's Avatar
I know 2 guys who are running the vtx10r with a 550 motor in the losi ten- scte at full weight and from the temps i saw on the esc, there is no need for a fan, and this was in 95* weather, however with a different motor and track, there might be a need, but i would try it without first.
jsamarin is offline
Old 09-06-2011 | 01:01 PM
  #2545
SaladFork's Avatar
It's anyones guess to how the Tekin motor will run on the VTX10R. Viper recommends using a fan when using the 550's. We will be releasing a VTX10R fan kit by the end of the month. The VTX10's are tiny so moving that heat away from the ESC is more difficult than a larger foot print ESC, the fan will help. If you try it without the fan, temp the ESC every 3 minutes.
I run mine without a fan and have for months. We did have a few problems in high heat areas where the ambient track temps are 120 and above. As a safety precaution we are recommending using one moving forward.
SaladFork is offline
Old 09-06-2011 | 01:44 PM
  #2546
rcgod's Avatar
Thanks for the info guys.
rcgod is offline
Old 09-06-2011 | 02:57 PM
  #2547
SaladFork's Avatar
Anytime!
Originally Posted by EastwooD-
Dont forget soup i want that 4 pole sensored 4wd motor let me know when its coming i want to be one of the first in line.
Thanks Eastwood, I have not started on the sensored designs yet. I'm really looking forward to getting all these options out to you guys. Just buttoning up a few things on the sensorless versions, then on to the sensored.
Old 09-06-2011 | 05:40 PM
  #2548
The Viper will work fine, just make sure you turn the Throttle Punch down to 80% or less, or the ESC will overheat and shut itself off.
Stealth_RT is offline
Old 09-06-2011 | 06:02 PM
  #2549
rcgod's Avatar
So I have to limit the punch to keep it from thermalling? If so sounds like I should put a fan on it.
rcgod is offline
Old 09-06-2011 | 06:41 PM
  #2550
smokinu's Avatar
Normally those are the LED's that flash when our product is over heated. dose it turn on and flash or do they start flashing after a while during a run?
direct any further comments to [email protected]
smokinu is offline
