Like Tree4Likes
Viper RC -
Old 06-27-2011 | 09:14 PM
  #2071
Dlewis4's Avatar
R/C Tech Elite Member
Originally Posted by bring it on
Ok, I have 2. LOL
1700 and an 1800... and access to a 2450
Dlewis4 is offline
Old 06-27-2011 | 10:23 PM
  #2072
Here are the results of my Nitro Buggy A main. There was only 3 e-buggy's today so we had to run with the nitro's. You can see what position i was in when we pulled off at the 14 minute mark. The number in front of the lap times tells you what position your in. I got 1st place today. The viper 2050kv motor with the new test
14.5mm rotor ran GREAT.
Would you mind sending us some test results. We have handed out many motors and rotors and never seem to get test results. Funny how that works. It would be greatly appreciated.
SC_RAGE is offline
Old 06-27-2011 | 10:24 PM
  #2073
Originally Posted by tibbs
My esc did the same thing it just shut of and won't turn back on and if it did turn on when u give it gas it just shuts down . I was using a viper 17.5 and it never got warm so I sent it in last week so we will see what they say?????? I had only used it maybe 5 times before this happened...
Pm me your name and I can tell you what the status is on your esc. I probably inspected it.
SC_RAGE is offline
Old 06-27-2011 | 10:33 PM
  #2074
wow, really? Weylin has tons of testing results and i just talked to him today for about 30 minutes on the phone. I can send you the results to if you like? What's your email? Do you not work with Weylin?
bring it on is offline
Old 06-27-2011 | 10:48 PM
  #2075
We have nothing at the office on paper as far as I know. And im there every day. What rotors have you tested?
SC_RAGE is offline
Old 06-27-2011 | 11:56 PM
  #2076
mcheroke's Avatar
Had a great day of testing and found some helpful settings for those of you running our VTX10R ESC and planning on running our 550 motors.
VST4.5XL-14tooth pinion. VTX10R-Profile#2, Brake strength 80%, Brake PWM freq 8000HZ, Brake curve linear, Neutral drag brake 10%, Throttle PWM freq 9600Hz, Throttle punch 15%-20%, Throttle curve linear, Deadband middle, no timing- default, no motor protection, esc protection 240 degrees. (esc temp 120-140)-(motor temp 150-170)
Raced at West Coast RC Raceway yesterday and dialed this setup in my sc10 4x4 w 10r and tekin 4.5 and these settings were MONEY! Dialed in a little more motor punch and some more drag break but it made the truck drive much smoother and was able to get my temps in range w/ the 14 tooth pinion. Thanks Rage for the info
mcheroke is offline
Old 06-29-2011 | 07:48 AM
  #2077
UK.hardcore's Avatar
How high is VTX10 from bottom to top of powers caps?
thanks
UK.hardcore is offline
Old 06-29-2011 | 09:31 AM
  #2078
thanks
16mm exactly
SC_RAGE is offline
Old 06-29-2011 | 09:33 AM
  #2079
This is why we test. To get starting points that wont blow up equipment. I should have some more options after I get back from california, so keep your eye on this thread. I will be posting.
SC_RAGE is offline
Old 06-29-2011 | 11:28 AM
  #2080
I just ordered one of the 13.5s for 2wd buggy, can't wait to try it. Now I kind of wish I would have waited to see how the 1/8th system works but I went with the Tekin.
Brian Alderman is offline
Old 06-29-2011 | 12:02 PM
  #2081
You should have no problem selling the tekin when the viper esc comes out..lol
SC_RAGE is offline
Old 06-29-2011 | 01:51 PM
  #2082
16mm exactly
So 16mm to its highest point. thanks.
Old 06-29-2011 | 03:49 PM
  #2083
I received a email from amain today telling me the Viper 4.5 550 can motors are in stock. I'm curious to know is there any difference in these motors compared to the others on the market? I'm a somewhat electric newb coming to electric from nitro, I've got a 4.5 novak still new in the package that's going in my scte once I get the final hop up parts so I was just curious if there's any major design or performance differences. Thanks
WideOpenThrottle RC is offline
Old 06-29-2011 | 07:20 PM
  #2084
6-26-11 Here are the results of my Buggy A main. I was running a caster 1.5r pro, viper motor, tekin esc, truerc battery and panther tires. There was only 3 e-buggy's today so we had to run with the nitro's. You can see what position i was in when we pulled off at the 14 minute mark. The number in front of the lap times tells you what position your in. I got 1st place today.
Old 06-29-2011 | 07:22 PM
  #2085
6-26-11 Also had only 2 e-truggy's so nitro class it was. Again pulled off in 1st place. 2011 caster e-truggy pro, viper motor, tekin esc, truerc battery and panther tires.
