Like Tree4Likes
Viper RC -
Old 02-26-2011 | 11:29 PM
  #571
mini-dub's Avatar
Trevor - you may want to try running default 30* motor timing and gearing up one or two teeth. Our motors are very torquey and lower motor timing increases the torque even more, allowing it to pull a very tall gear Let us know what works best!
mini-dub is offline
Old 02-27-2011 | 01:40 AM
  #572
smokinu's Avatar
Originally Posted by nikos2002
Reuben - congrats!!!! Awesone Job!!!! You got a nice combination there!!!
Trevor - great work, thanks for the info!!
i should be getting my vtrax10 in to pair with a 13.5 and an 8.5 in my 2wd buggy
bumping from the 13.5 class to expert mod after just one 7 race series were i am sitting in 2nd in points.. dont think i have a chance at winning unless the leader in points misses the last race.
smokinu is offline
Old 02-27-2011 | 09:09 AM
  #573
Trevor Williams's Avatar
R/C Tech Elite Member
Hello Weylin...
Yeah, that's what I was thinking as well, a LOT more gear and when I do re-gear and find my "sweet-spot" I will go back to 30° of timing on the external ring and work with the setup from there......I cant wait to pair this VST with a Vtrax10
More than just power......INNOVATION!!!
Trevor Williams is offline
Old 02-27-2011 | 09:12 AM
  #574
dug44's Avatar
So, what is it with the whole timing thing anyway? I bought a 17.5 and have it hooked up to the traxxas esc... How does the whole timing thing work? I have been wanted to mess with it, just don't wanna mess it all up...
dug44 is offline
Old 02-27-2011 | 09:29 AM
  #575
It can get very technical and deep to fully explain/understand how it works, there are a lot of factors and variables involved, due to my lack of knowledge at that level I cant go greek with it, LOL....I am still learning myself everyday.....An easy way for me to sum it up in a few words would be this:
Adjusting the external motor timing will have a very noticable increase in performance. Dont be afraid to experiment with it
Typically:
More timing - More rpms, less torque.
Less timing - Less rpms, more torque.
Keep an eye on temps and find the right gearing setup to achieve maximum power and efficiency for your layout(remember to keep track/make logs of where you're geared at so you can cross reference to your changes and compare to find the sweet-spot that feels good to you and is efficient) I generally try to gear where I can clear the largest obstacles, and have strong, yet very managable torque to get me around all of the technical sections on our current layout. 90% of our current layout is very technical where a lot of top-end is not needed.
Old 02-27-2011 | 10:05 AM
  #576
Can you guys share gearing for 2wd buggy, truck and short course with 8.5s in them all. Anything with a 2.6 trans such as b4, rb5 or x6.
JDriemeier is offline
Old 02-27-2011 | 10:59 AM
  #577
smokinu's Avatar
24-26/75
smokinu is offline
Old 02-27-2011 | 11:04 AM
  #578
dug44's Avatar
Trevor, i appreciate it.... Thank you. Just wanted to make sure i wasn't gonna hurt anything. Thanks again.
dug44 is offline
Old 02-27-2011 | 11:06 AM
  #579
My pleasure buddy, I hope it helped some
Viper R/C Solutions - More than just power......INNOVATION!!!
Old 02-27-2011 | 12:02 PM
  #580
mini-dub's Avatar
2wd - 23/84
short course - 18/84
truck - 20-21/84
If you're running a large outdoor layout try going up a tooth, these ratios are from an average size indoor track.
Originally Posted by smokinu
24-26/75
Whoa whoa! Unless you're running on a 1/8 onroad track don't think you're going to want to run a 75t spur.
mini-dub is offline
Old 02-27-2011 | 12:11 PM
  #581
Ok thanks! That's what I had but the temps were higher than everyone else has reported. There was alot of traction last night and my throttle finger might have been a little heavy to.
Old 02-27-2011 | 12:16 PM
  #582
mini-dub's Avatar
Yeah traction always plays a huge factor in component temps, plus when you have lots of bite you can rip on it hard. As long as you're coming off below 140* you're fine. If it's much higher than that then I expect some part of your setup (gearing...) needs to be improved. As far as protecting the motor I just like to make sure they stay below 180* on a run to run basis. It's near impossible to reach that temp in an offroad car though.
mini-dub is offline
Old 02-27-2011 | 01:05 PM
  #583
smokinu's Avatar
2wd - 23/84
short bus - 18/84
truck - 20-21/84
yeah i ment to say 81 i will be testing gearing very soon
the vtrax10 should be in next week so i can really Get some testing going!
smokinu is offline
Old 02-27-2011 | 01:12 PM
  #584
mini-dub's Avatar
Cool cool just making sure. Cant wait for you to run the Vtrax
mini-dub is offline
Old 02-27-2011 | 01:16 PM
  #585
Dlewis4's Avatar
Ran my FS2 powered by a 13.5 Viper last night in the 4wd Mod class at the Jakes RC Pro/AM in Topeka, KS. First night out with the FS2. Everyone in mod was running a 6.5 or 7.5... not me. 13.5-qualified 6th in the A and ended up placing 6th. Not bad when the top 3 are full on pro's....
Another great race weekend with the VTrax/VST setup.
Dlewis4 is offline
