NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 06-03-2013, 07:40 AM
  #11011
chasingthepack's Avatar
hi all,i have an orion r10 pro,similar to the hw,i seem to have a delay on the brakes and cant work out why or how to get rid,when braking for slow corners its ok but hit the brakes from high speed and there is this delay,its annoying as the brakes are kicking in just as i hit the apex and then locks the fronts so i run wide,its costing me time,any help would be appreciated
chasingthepack is offline
Old 06-03-2013, 08:49 AM
  #11012
Originally Posted by XXXDad
Make sure you are fully updated on your ESC....
First re calabrate your throttle neutral/foward/brake... Try neutral range Low 95 and check inital break setting . I run 62.5% brake setting then set your dragbreak to 10% or higher, if low traction 10% is good if higher traction try a higher %... you just dont want the rear end to come around. So if its spinning out use a lower drag break setting. Do you have the program box??
yes tried all that and yes i have the programmer
Originally Posted by lore
Hi, have you tried initial break set up to 40?
Tha should help.
Ciao,
Lorenzo
yes,i have tried just about everything to lose the delay but its still there,i have taken a vid of whats happening,knowing my luck thats just the way it is,once i have it uploaded ill post it here
Old 06-03-2013, 10:20 AM
  #11013
heres the vid
http://youtu.be/ljFsxIaV05Y
Old 06-03-2013, 04:18 PM
  #11014
I am currently using an Xtreme Stock ESC in a 1/10 2WD buggy, with a 13.5T SP MMM motor on 2S LiPo. I want to change over to a SP V3 8.5T motor, but will the Xtreme Stock be OK with this setup, as the 'official' specs say 'with 2S Lipo or 4-6 cells NiMH, 1/10 on-road>=8.5T, 1/10 off-road>=11.5T'.
I won't be running any boost or turbo, but should I be looking at using a 90A or 120A ESC with the 8.5T instead to be on the safe side? This is for track use only, but it will be used for 15 minute practice runs as well as 5 minute races.
Toon is offline
Old 06-03-2013, 04:39 PM
  #11015
COBRARACING's Avatar
The xtreme stock will work fine no problem.
COBRARACING is offline
Old 06-03-2013, 04:44 PM
  #11016
You are running a 4pk radio ? Can you tell me what have you set your end point on your radio to ?
Old 06-03-2013, 04:46 PM
  #11017
Old 06-04-2013, 12:28 AM
  #11018
its a 4pl end points are 90 left and 114 right,throttle and brakes on full
Old 06-04-2013, 12:30 AM
  #11019
And full is 120% ? If it is drop it to 100% and the delay will be elliminated.
Old 06-04-2013, 07:25 AM
  #11020
esckalayd's Avatar
Default XERUN 1S 120a V2.1
Its been awhile since i used/raced with my 1S 120A V2.1 Hobbywing ESC. I plugged it in last night and update the software to the currently support one. I believe it was V1.08_25405??? It was not the V1.11_3 b/c i saw on the side that that version was unsupported for the older ESCs.
My question is, is anyone running this 1S 120A V2.1 speedo in a 17.5 touring car for blinky? Also, i see it supports MOD as well 3.5T or higher, has anyone used this speedo for mod? I will be initially using the speedo with a reedy 17.5 but would possibly change it out for a 4T mod motor.
Thanks for any suggestions
esckalayd is offline
Old 06-04-2013, 07:42 AM
  #11021
Trader Rating: 27 (100%+)
My brother uses a v2.1 1s model in a 17.5 blinky sedan. Got no complaints at all. Switched from a Tekin RS Pro to it.
hyujmn is offline
Old 06-05-2013, 01:29 PM
  #11022
Hi,
I know at least two guys that use it since one and a half year in mod, with 6.5 to 4.5, without any problem.
Just watch the temp while trying different gearing and boost/turbo settings.
FFred is offline
Old 06-05-2013, 03:06 PM
  #11023
http://www.hobbywing.com/product_show.asp?id=218
New usb link with open control file to allow you to change from old to new and new to old firmware
Old 06-05-2013, 06:55 PM
  #11024
RoyB's Avatar
Trader Rating: 19 (100%+)
Just put in a V3.1 stock spec esc. The Hardware version is HOBBYWING_456_V2. The software version is V3.1_121129_Beta. The database version is 130516. Is this the newest software? It is the newest that comes up for me on on USB link V3.3.
RoyB is offline
Old 06-05-2013, 06:57 PM
  #11025
Correct 129 is the latest for the v3 range
