NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE
THanks
Dan
Hi guys
just to let you know the new v3.1 or v3.0 heatsink and fan assembly that has been tested will be a option part for the ones who are looking for more performance less temp
I have attached a photo which according to our test results gave us 30% more airflow ,fan 50% more thrust and 12% less temp .
Hi guys
So the firmware is the same between the v3.1 and the stock spec ESC right? Only difference is the motor turn limit?
My v3's fans are always breaking fins I've gone through so many this year, I do have the muchmore plate ontop (not sure if this is the issue) and I have mounted the fan with orings inbetween it and the speedy, this helped but they still always break fins ! Anyone with the same problem? Anyone have a fix?
Btw Angelo, I think it would be a good idea to release the next speedy coming (blue version) with the black fan, it looks way better than a clear fan
Agreed i hate the clear fan .lol black suits anything from blue to red and its original black case.
Setup required
Hey Guys,
Looking for help with a setup, running a HW xtreme stock with a Speed Passion 3.0 21.5t open boost and turbo.
Low traction track, long main straight 65metres with mixed infield.
So just looking for what FDR and esc setup if anyone can help?
Boost 40
Turbo between 20 and 24 depending on how much endbell timing you run, again see what the car is doing and tune from there
Timing acc 300
Turbo delay 0.1
These are general settings that will point you in the right direction. Getting a really good 21.5 boosted setup takes allot of track time and testing!
Gearing between 4 and 5 so start at 4.5 and tune depending on what the car is doing.
Boost 40
Timing acc 300
Turbo delay 0.1
Boost 40
Timing acc 300
Turbo delay 0.1
What DRRS should I run and boost timing rpm?
Sorry i forgot those! Start rpm 3000 or 4000
DRRS level 9 (maximum setting)
