Keyence ESC
Old 08-30-2005 | 09:08 PM
  #511
Originally Posted by Charles_Howarth
Ok.. So I got the wires taken care of or so I thought.. The car only runs in reverse.. I tried reversing my radio, switching the wires,etc... I ran through the setup to set neutral, high point and low point with no luck..
I guess my question is that since I believe i have the wires connected correctly, is it most probable that I have to adjust the ESC setup?
Any help would be appreciated.
Charley
It sounds like your setting the speedo by itself, but not binding it up to your transmitter correctly(or at all)......I did this in the past with similar results like you mention.....make sure you follow the instructions to set it to your transmitter..."then" do you speedo settings like, nutrl brake, nutrl brake freq, drive percentage, drive frequency.....Ect.......
Joe B is offline
Old 08-30-2005 | 09:17 PM
  #512
Charles_Howarth's Avatar
Thanks to all that replied.. I got it to work and have it set on the P5 setting.. I'll give that a shot and go from there..
Charley
Charles_Howarth is offline
Old 08-30-2005 | 10:17 PM
  #513
moot's Avatar
is there anywhere that i can send my rapida pro to be reconditioned? it works but the case and buttons are stuffed.
moot is offline
Old 08-31-2005 | 04:20 AM
  #514
cheehtae's Avatar
send it to Shumacher, they are the distributor and have grrreat customer service. Right Tony I mean Adrian.
cheehtae is offline
Old 08-31-2005 | 07:37 AM
  #515
can anyone help?
what will happen to your speedo when you connect a full battery pack to the motor? what happened is this. To test the drivetrain someone connected the battery pack directly to the motor while the speedo was still connected. can this cause any harm?
thnx in advance,
santosh.
Santosh is offline
Old 08-31-2005 | 09:40 AM
  #516
AdrianM's Avatar
This is a very bad thing to do to any speedo! It can blow all the FETs out on the main board.
Try to run the speedo. If it works you are very lucky. It may have blown a few FETs and it may work but at a reduced performance level. If you are slow next time you race with known good motors and batts then you have damaged the speedo.
AdrianM is offline
Old 08-31-2005 | 11:41 AM
  #517
Adrian, thanx for your help. Makes me feel good and bad ;-)
Bad because the car worked and when I went to max speed a lot of smokes came out of the speedo... it died... and almost took out the receiver too.
Good because I love keyence speedo's and now I am going to put in another one knowing that there is nothing wrong with keyence speedo's!
Santosh is offline
Old 08-31-2005 | 11:48 AM
  #518
AdrianM's Avatar
Send the blown speedo in for replacement. It costs $50. Put a note in the box and we will call you for a CC# when it arrives.
AdrianM is offline
Old 08-31-2005 | 11:52 AM
  #519
1fastdude's Avatar
Awesome service and turn around. Hard to beat now a days!
1fastdude is offline
Old 08-31-2005 | 12:51 PM
  #520
? wow.... that is great service....
will send it back ...but beware... it smells ;-)
Santosh.
Santosh is offline
Old 09-01-2005 | 06:56 AM
  #521
purpurite's Avatar
purpurite is offline
Old 09-01-2005 | 10:48 AM
  #522
JayBee's Avatar
AdrianM other than the profile that's somewhere in the middle of this thread, have you played with the numbers and found a better profile for stock motors? -JB
JayBee is offline
Old 09-01-2005 | 11:14 AM
  #523
AdrianM's Avatar
Not Really. I haven't raced stock in 2 years. I run mostly Open Mod and 19T.
All you would really change is drive freq. The lower the better up to about 1.5. Of course this is limited by your throttle finger. If you are a real hammer on the trigger you won't be able to run a low freq. You will burn up your comm and brushes 3 minutes into a run.
AdrianM is offline
Old 09-01-2005 | 11:24 AM
  #524
JayBee's Avatar
Thanks...
JayBee is offline
Old 09-04-2005 | 05:20 AM
  #525
Hi,.....
Just wondering what's a good starting frequency for 19T in 1/12th. The 15Khz mentioned in the instructions seems a little high lol?
While I think about it would running the Rapida Pro on 4 cells/19T/3700mah with a personal transponder be ok without a receiver pack?
Mabuchi540 is offline
