Keyence ESC
#482
Originally Posted by Mabuchi540
I was looking into this myself a while ago and if the specs of all the makers are correct from lowest resistance to highest it goes something like.....
Novak GTB in brushed mode,
Tekin G11,
Rapida Pro,
Novak GTX.
Not sure where the KO fits into that lot, couldn't find voltage drop specs for it.
Tekin G11,
Rapida Pro,
Novak GTX.
#483
Originally Posted by AdrianM
Can you post the numbers and whether they are for the complete FET board or just the sum of the FET resistance?
Novak claims the GTB in brushed mode is.....0.00013
Tekin G11.....0.00020
Rapida Pro.....0.00023
GTX.....0.00034
#484
I have been reading a few pages of this thread and to me..I think you would never be able to tell any differences in the resistance of the fet's(the # that were talking about with the mid to upper speed controlers)The bottom line with speed controlers is on the track performance,I just got one(from STLNLST..THANKS..
)GREAT speed controller,I rate it above the GTX, LRP Comp 2, GM V12, and the KO (the KO is a good speed controller)The speed controller I'm using is the Zero ex.It has the best punch for stock racing I have ever used.
#486
#487
I have no idea what part in relates to, it's just the figure I saw on their websites (ohm resistance).
GTX.....0.00034
GTX.....0.00034
However, Neither of those speed controls are even close to offering the features and adjustablilty of the Rapida.
#488
From: Castle Mamba Max Pro. Feel its power!!!!!!!!!!
Time moves on an others have caught up. Tekin and Novak will have us by a few millionths of an ohm when these new speedos come out.
#489
I have the Keyence Zero now and was thinking of getting another esc like the Rapida. I like my Zero that I run now and if the difference is not that great I will look at maybe another Zero for a spare or a Rapida for my race one and the Zero for my spare.
#490
Originally Posted by wyd
With numbers being so close do guys really notice a difference from .00020 or .00023. I would think that you would never notice that on the track.
#491
just want to add my 2 cents worth...
When I bought my TA-05 I wanted to go with a new ESC, so after having spent countless hours reading through the various posts on which ESC is the best I decided on the Rapida Pro. I can very happily tell you that it was definately the right decision, I ran the Rapida Pro back to back with a Novak GTX and the first thing you notice is that the Rapida Pro is by far smoother and does not run as hot either and that's without the heatsink or a power cap installed. The features available on the Rapida Pro are very impressive and are not as difficult to setup as some posts make it sound, the GTX was a little bit more punchy but I will play around with the drive frequency to remedy that.
#492
#493
Man, the instruction manual for this thing makes me feel like I'm reading another language. Setting this ESC up has the effect of taking off about 80 I.Q. points right off the top.
I think I need to play with it a bit more, but learning all of the settings on this, plus a brand new Futaba 3PK, I have realized I miss the old days of turning one dial on a Novak T1x to get everything set up.
Good god, I feel like a moron right now.
I think I need to play with it a bit more, but learning all of the settings on this, plus a brand new Futaba 3PK, I have realized I miss the old days of turning one dial on a Novak T1x to get everything set up.Good god, I feel like a moron right now.
#494
#495
Ok, so I have been playing with this ESC for a couple of days now, and I'm starting to figure it out. First, using the correct half of the manual helps considerably. Once you get a handle on how the different variables are set within the ESC, and then understand what the variables actually are, this becomes a super cool piece of the electronic puzzle.
You're right, I can't see myself going back to a Novak product.
This thing is pretty dern cool.
