Keyence ESC
Old 08-30-2005 | 08:30 AM
  #496
Charles_Howarth's Avatar
Hi All,
I bought a used Keyence 2002 and did not receive an instruction manual.. Which wire goes to what on the right side of the case? I have 4 wires and assuming(if you are looking down on the right side) they are numbered 1-4, how would they attach to the motor and battery?
Any help would be appreciated.
Thanks,
Charley
Charles_Howarth is offline
Old 08-30-2005 | 10:15 AM
  #497
The largest tab(closest to the led screen) is for motor and battery POSITIVE......the middle tab is for motor NEG.....and the top tab is for battery NEG .......Get yourself an instruction booklet(mabe one of these guys can tell you if keyence's site has downloads)...you'll probably need it in the begining
Joe B is offline
Old 08-30-2005 | 10:20 AM
  #498
Great, thanks..
Charley
Old 08-30-2005 | 10:22 AM
  #499
no prob
Joe B is offline
Old 08-30-2005 | 10:27 AM
  #500
http://hobby.keyence.co.jp/english/manual.html found it
Joe B is offline
Old 08-30-2005 | 10:37 AM
  #501
Awesome... Thanks.
Charley
Old 08-30-2005 | 11:10 AM
  #502
nnick's Avatar
Shop Owner
Or here
http://www.rcingreece.com/index.asp?...ls&Car=Keyence
Nick
nnick is offline
Old 08-30-2005 | 11:41 AM
  #503
AdrianM's Avatar
Originally Posted by Joe B
no prob
Joe - Jason should have your speedos today. We sent them to BMI since there was no address on your note.
AdrianM is offline
Old 08-30-2005 | 02:58 PM
  #504
cheehtae's Avatar
What's the yellow wire that comes out of the v zero extreme?
cheehtae is offline
Old 08-30-2005 | 03:03 PM
  #505
rc_bam226's Avatar
If I'm not mistaken, that would be the 1.2V lead for servos that are 7.2 powered. Your servo should have an extra lead for that, and it should obviously note somewhere that it is a 7.2V servo.
rc_bam226 is offline
Old 08-30-2005 | 03:37 PM
  #506
Ok.. So I got the wires taken care of or so I thought.. The car only runs in reverse.. I tried reversing my radio, switching the wires,etc... I ran through the setup to set neutral, high point and low point with no luck..
I guess my question is that since I believe i have the wires connected correctly, is it most probable that I have to adjust the ESC setup?
Charley
Old 08-30-2005 | 03:41 PM
  #507
purpurite's Avatar
Silly question, but never overlook the obvious. Did you check that the motor leads are soldered on properly? Sounds as if you have them on reversed.
purpurite is offline
Old 08-30-2005 | 03:48 PM
  #508
And that was my first concern and tried the leads from the ESC both ways on the motor.. It seems like such an obvious solution but I am stumped. I am putting it all down for awhile and will try it again..
Charley
Old 08-30-2005 | 06:01 PM
  #509
purpurite's Avatar
By reversed, I mean the red wire to the — post on the motor, and the black wire to the + side. Also, be sure to download the instruction manuals from the Keyence website, as they have pictures to compare to make sure you have it wired up correctly, too.
Old 08-30-2005 | 09:02 PM
  #510
Thanks Adrian, PM
Joe B is offline
