Motor Testing and Comparisons >
Like Tree530Likes
Old 01-07-2026 | 04:49 PM
  #511
OffRoadJunkie's Avatar
Originally Posted by bertrandsv87
The whole point of motor tuning is to find the sweet spot of only the motor you are testing at the time you are testing it. Compare two different motors on the same track layout to see which one lowers your laptimes on that layout, but it does not mean that the slower motor on that layout will stay slower on a different layout. At some point the track performance will rule over spread sheets, and you'll need to make the correct choice of motors for the layout of the race...
Absolutely! I say this same thing at the end of all my videos. To choose the right motor, you have to consider what track you're racing on, what type of vehicle you are racing, and what type of a driver you are. This is why I never say there one "Best Motor."
bertrandsv87 likes this.
OffRoadJunkie is offline
Old 01-07-2026 | 04:58 PM
  #512
gigaplex's Avatar
Originally Posted by OffRoadJunkie
True, a higher torque motor can draw more amps. But then you're pulling a lot more heat. It's like adding a 2000 gauss rotor to a 17.5 stock motor. You'll get a lot of torque, but it gets too hot to race. About 99% of the racers out there will gear their motors until they hit the brink of thermal meltdown. Motor that draws too many amps will generate too much heat which will greatly limit your gearing.
As for efficiency and torque, efficiency turns into more usable torque. With stock motors having so many regulations, and after testing roughly 20 motors over the past few years, I found efficiency does end up meaning the motor has more torque. Also, while I was working for VIA Motors, as a sub-assembly Supervisor, to find the torquier motors, we looked efficient running motors.
With IC motors, RPM doesn't really determine what motor has more torque, but I don't think I am fully understanding the comment. However, a 5.0L diesel will have more Torque than a 5.0L petrol motor. The diesel is also a lot more efficient.
Anyhow, this is very complex conversation that cannot be discussed in a chat room. A lot of questions and examples need to be shared in order to understand what both of our thoughts are, on this topic.
RPM drastically affects the torque output of an IC motor. Putting 2 different motors under the "same load" could put the motor way out of it's torque band, making it look like it has poor torque, when really it might have way more peak torque at a different RPM. You often need to put them under different loads to compare them. The Jerry only tests the steady state where the RPM is at equilibrium.
OffRoadJunkie likes this.
gigaplex is offline
Old 01-07-2026 | 06:30 PM
  #513
Mac The Knife's Avatar
R/C Tech Elite Member
Well Giga, you gotta start somewhere, and since I don't have a motor dyno, and you don't offer anything up other than arguments, I'll use OffRoadJunkie's findings as a starting point, and use the datalogging of my esc with the car on the track to make any adjustments from there.
Mac The Knife is offline
Old 01-08-2026 | 02:38 AM
  #514
G-rem's Avatar
Very interesting point, so let's say I put a mod motor in a 21.5t stock motor, for the same ratio and ESC tuning, it will always run hotter then ?
G-rem is offline
Old 01-08-2026 | 05:09 AM
  #515
gigaplex's Avatar
My recommendation for using The Jerry as posted in a different thread:
Peak power is usually at half of the no-load RPM. So, measure the no-load RPM, then adjust the gearing with the slave motor to make the master motor run at half of that RPM. Measure the output RPM of the slave motor. Repeat the process with the motor you're comparing against. The motor with the highest peak power should be the one with the highest RPM of the slave motor.
This is still just an approximation though, you need a proper dyno to be accurate as peak power isn't guaranteed to be strictly at the half RPM mark. You can still use it as an estimate for a starting point, and gear up/down slightly to see if you get any increases in the slave output RPM.
gigaplex is offline
Old 01-08-2026 | 05:39 AM
  #516
I don't have a "Jerry", or a Tunalyzer, and the majority of us don't either. I do have a SkyRc analyzer, so what OffRoadJunkie provides for information gives me and others a starting point.
Old 01-08-2026 | 09:57 AM
  #517
I see what you're talking about now. I now see that we are viewing this under a different light. Yes, motors need to be chosen by knowing how they perform under different loads. I totally agree. You wouldn't use a high torque motor for a large on-road track with long straights.
The best thing about The Jerry is, it allows you to see what motors can do under the same load. If you hook an ESC to it, you can do even more. To simulate short tracks, you can throttle on and off, for a while, and see what the heat and motor stats are. To test for an RPM motor, you can hold the throttle wide open much longer, then test the heat and motor stats.
Old 01-08-2026 | 10:11 AM
  #518
It depends on how you gear it and tune it. However, it will not be a good motor for high-speed tracks.
nitrous36, RacinJ and G-rem like this.
Old 01-08-2026 | 06:31 PM
  #519
So,
I got the Team Powers V6S on my bench. It turned out to be a dud. While adjusting the timing, when I reached 40*, the motor didn't have enough torque to finish the Autorun cycle, with the Tunalyzer, while on the Load Master. At $175, with tax and shipping, this is the most I have ever spent on a motor. I really hope they have a warranty on this.
Old 01-08-2026 | 06:34 PM
  #520
They'll probably send you a new one...
bertrandsv87 is offline
Old 01-08-2026 | 09:08 PM
  #521
trilerian's Avatar
So,
Did it stall on the last part of the run? That part of the cycle is done in sensorless mode and is where the timing is measured. When it stalls it is a cogging issue, you can spin it and it will be fine.
gigaplex likes this.
trilerian is offline
Old 01-08-2026 | 09:32 PM
  #522
STLNLST's Avatar
I have rotors in the 18’s that are are just as fast as anything else being run. The onroad track in Fresno is large, open, with sweepers. I’ve proved this in sedan and just recently in 12th scale at Lemo’s carpet track. Both vehicles had 21.5 motors. With the higher torque motors I can’t stress enough of low can timing and gearing up to get the top end back. I can almost assure you that the V6 you currently have is just as fast as every V6 I’ve played with when timed and geared correctly.
STLNLST is offline
Old 01-09-2026 | 12:55 AM
  #523
gigaplex's Avatar
I was replying to OffRoadJunkie who was comparing current draw while using The Jerry.
gigaplex is offline
Old 01-09-2026 | 12:56 AM
  #524
gigaplex's Avatar
So,
Have you tested it on track? The one I've seen is pretty quick.
STLNLST likes this.
gigaplex is offline
Old 01-09-2026 | 01:34 PM
  #525
Im hoping so.
