Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Project: Break in Dutch machine >
Like Tree20Likes
Old 09-15-2018 | 11:50 AM
  #211
Originally Posted by 1/8 IC Fan
What????
You linked Harbor Freight, they do not carry the EBIS. Rctarget has their version.
https://www.liverc.com/news/new_prod...eak-In_System/
Is this a different machine?
What happened to the original 'creator' and his EBIS?
GAMER is offline
Old 09-15-2018 | 02:22 PM
  #212
Roelof's Avatar
What????
Thats a bummer... somewhere in the beginning of this project I sugested a small deep fryer and what do I see here, a base of a small deep fryer....
Roelof is offline
Old 09-16-2018 | 09:30 AM
  #213
wow Rctarget homemade version is expensive than the high quality EBIS.
I will used that harbor tool to made the roelof machine work with the motor mounted in horizontal position .
rccaricatura is offline
Old 09-16-2018 | 06:22 PM
  #214
Default My DIY EBIS
used it this weekend not finished yet still have to add temperature gauge RPM gauge worked great the small fry idea work great
Wjones1040 is offline
Old 09-17-2018 | 02:50 AM
  #215
Default DIY EBIS
one bottle of 0w 20 fits perfect ...
Old 09-17-2018 | 04:00 AM
  #216
Roelof's Avatar
Nice! and easy to put away with the oil in it. But remember the deep fryer need to go as 100 degrees celcius. Many do start with a higher temp. But replacing the theromstat for a different one with a better temperature range is easy.
And I would use a different flexcoupler, a version with a clamp constructio instead of this one with a grubscrew, just not to damage the crankshaft.
Roelof is offline
Old 09-17-2018 | 08:41 AM
  #217
Default DIY EBIS
Yes the temp stayed automatically at 200 degrees... not really going to replace the temperature control but more of a monitor so if I need to adjust the temperature. I ordered the wrong Flex coupler it was the wrong size first one I had was a clamp but it was a 6 not a 6.35 to a 5 mm.
Old 09-17-2018 | 08:55 AM
  #218
Roelof's Avatar
Just drill the 6mm hole up to 6.35mm (1/4")
Roelof is offline
Old 09-18-2018 | 11:00 AM
  #219
Roelof's Avatar
Looking at that RCtarget....
The base unit:
Amazon Amazon
The timer:
https://www.ebay.com/itm/12V-Thermos...-/401229762943
The RPM meter
https://nl.aliexpress.com/item/Digital-LED-Punch-Tachometer-RPM-Speed-Panel-Meter-4-digit-9999RPM-Tacho-Gauge-Hall-Proximity-Sensor/32671761984.html
I
think on the inside a normal brushed motor is used with an el cheapo PWM controler
OK, nice looking case which is not that difficult to make fittin on the top cover of the mini deep fryer.
With outsourcing the bending and CNC milling of the materials I do not think the total costs will go above 350 dollar. I think they can share some fee with me for the idea
rccaricatura likes this.
Roelof is offline
Old 10-06-2018 | 08:36 PM
  #220
choisan's Avatar
i am no good of building, may i know where i can buy ebis or similar now? i missed the very first lot, but just want to have one after 2 years, to save tire and fuel
choisan is online now
Old 10-06-2018 | 10:11 PM
  #221
Roelof's Avatar
On Facebook you can find the EBIS product page (not to confuse with EBIS Australia). You can contact the builder RichardE on this forum.
And arround the world there are now several oil bath break in devices to find.
Roelof is offline
Old 10-07-2018 | 08:28 AM
  #222
1/8 IC Fan's Avatar
Yeah, I have tried messenger for a while but Richard is not responding. May be rather busy.
1/8 IC Fan is offline
Old 10-07-2018 | 08:30 AM
  #223
choisan's Avatar
he once replied lately that he is busy with family, not produce any now.
Old 10-07-2018 | 10:14 PM
  #224
Default DIY EBIS
EBIS control box completed system ready to go fully functional. Video to come soon
WFR products ready to go!
Who likes this.
Old 10-09-2018 | 04:54 PM
  #225
Which other ones are available?
GAMER is offline
