Old 08-22-2006, 07:18 PM   #136
afm
afm's Avatar
Default CRF Specs
Can anybody confirm if these timing figures are correct???
Induction:
Opens 15 ABDC
Closes 70 ATDC
Total induction 235
Total Transfer: 124
Total Exhaust: 172
What's the bore and stroke on this engine???
AFM
afm is offline   Reply With Quote
Old 08-25-2006, 03:23 AM   #137
gunna do's Avatar
Default head shim
hi my name is brett i just recieved my new crf 12 i'm running 16% fuel what head shim do i remove.I live in Brisbane Australia where we have a hot and humid climate can anyone share some info.
gunna do is offline   Reply With Quote
Old 08-25-2006, 04:48 AM   #138
razzor's Avatar
Have a buddy that just got a Wasp to fit into hes G4S.
Any guys have recommendations for gearing the G4S with the Wasp.
Some guys have said that they cant gear down enough to get the bottom end responsive enough.
Any ideas or recommendations welcome.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-28-2006, 09:35 AM   #139
Nano's Avatar
Here you go, official CRF gearing for the G4S :
-1st gear 18/52
-2nd gear 23/47
For the bottom end, the original clutch does not suit the engine well, you need to get our special clutch parts set. I have a G4S and the car flies with this engine
Nano
Nano is offline   Reply With Quote
Old 08-28-2006, 09:47 AM   #140
Nano's Avatar
Originally Posted by dameetz
Ijust bought the Peak Diablo version of this engine but haven't run it yet, i will when my RRR evo arrived . My question is, the crankshaft has a little bit of play around the bearing(you can move it lateraly or vertically), is this normal? From what i ve experience with other engine,this looks like sign of worn crankshaft bearing.
The lateral play is very normal and a little vertical can also be felt. It will be ok once you install the flywheel and make it tight.
Nano
Old 08-28-2006, 11:08 AM   #141
razzor's Avatar
Thanks Nano
We ran 18/52 23/46 ,car ran well.
Buddy managed to TQ and take the win in the A mains.
Engine ran a bit hot but it hadnt had more than 8 tanks through it by the finals.Sure there si more in there.
Casterracing ZX1.5R
Old 08-28-2006, 06:58 PM   #142
deviltires's Avatar
is it normal for these engines to run 300 deg im running 30% fuel after a 20min main my temp is at 300 but the engine has lots of power at that temp the only problem is when the engine get to idle it bogs really bad when i try to take off is this my clutch or is this engine tune and i have it on a mtx4 with the crf clutch
DARNELL WASHINGTON-- TEAM MUGEN----FUTABA 4PK--HOT RACE TIRES
deviltires is offline   Reply With Quote
Old 08-28-2006, 07:12 PM   #143
bigman18's Avatar
What is the best gearing for a Mugen MTX4. I tried mine this weekend and I was very pleased
bigman18 is offline   Reply With Quote
Old 08-28-2006, 07:27 PM   #144
rmdhawaii's Avatar
If you hear the deep "waugh, waugh, waugh" sound and your car doesn't go anywhere, it means that your low speed needle is too rich. When my engine runs at 300F, it's a missle, but I know that the high speed needle is a bit too lean. Clutch setting and 2nd gear shift point may also impact your temps, but if your clutch isn't slipping and your 2nd gear is shifting correctly after the engine has warmed up properly (3min), then it may just be your settings.
Some info posted by Brian Kinney may be helpful if you haven't already seen it:
- http://www.rctech.net/forum/showpost...&postcount=608
Hope this helps
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-29-2006, 02:27 AM   #145
Nano can you give me your clutch settings for the g4s?? Thanks a lot.
vitopelaez is offline   Reply With Quote
Old 08-29-2006, 08:17 AM   #146
Nano's Avatar
I don't remember exactly the setting because my engine and clutch are in parts right now and I haven't had time to run the car in a while.
One thing though is that when using the CRF clutch parts on the Team Magic, the nut that tightens the flywheel on the engine shaft is too short and that can cause problems with the clutch function. You want to add a spacer between the nut and the flywheel. This way you can tighten the spring adjust nut without making the spring too tight. I used a spacer that was 0.8mm thick. Then the spring adjust nut was tighetened about 0.5mm lower than the edge of the flywheel nut.
Hope this helps!
Nano
Old 08-30-2006, 07:21 PM   #147
deviltires's Avatar
Hope this helps
so should i have it to shift early or close to 1st gear is out
Old 08-30-2006, 11:21 PM   #148
rmdhawaii's Avatar
You don't want it shifting early.
Old 08-31-2006, 06:50 PM   #149
hi guys whats the recomended shims for the CRF if you are running 20% ?
reecek is offline   Reply With Quote
Old 09-01-2006, 08:25 AM   #150
Great newz and bad newz, can you say balestic?? I got the engine going even better than before, crazt fast talking 1/8 speed on our club track no lie. Glad so many other are afraid to run this engine from what they hear and the make, only give me the advantage . But one thing, engine kept shifting and was blowing gears in my RRR. Anyone else having this problem? I try with and without locktite but to no avail. I am to give it another go today. Big trohpy race sunday, and want to be ready.
CHUCKMANDO is offline   Reply With Quote
TEAM ORION .12 CRF WASP SERPENT CURACAO R/C Items: For Sale/Trade 0 03-08-2007 01:01 PM
****Team Orion CRF Wasp Rev .12**** polesitter61 R/C Items: For Sale/Trade 3 11-29-2006 03:52 PM
Team Orion WASP CRF .12 Z00M Australia For Sale/Trade 2 10-17-2006 04:33 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-09-2005 10:41 AM
