Old 09-01-2006, 09:41 AM   #151
rmdhawaii's Avatar
Originally Posted by CHUCKMANDO
Great newz and bad newz, can you say balestic?? I got the engine going even better than before, crazt fast talking 1/8 speed on our club track no lie. Glad so many other are afraid to run this engine from what they hear and the make, only give me the advantage . But one thing, engine kept shifting and was blowing gears in my RRR. Anyone else having this problem? I try with and without locktite but to no avail. I am to give it another go today. Big trohpy race sunday, and want to be ready.
The engine is not causing your problem. It's something else. Did you see this post? (click here) With the engine out of the car, does your 2nd gear spur spin freely? Make sure it's not binding up on the shoe.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 09-01-2006, 09:55 AM   #152
rmdhawaii's Avatar
Originally Posted by reecek
hi guys whats the recomended shims for the CRF if you are running 20% ?
20% is on the border. You can run it with two shims or with just one shim. You need to determine what's best in your particular situation, based on plug selection, fuel brand and environmental conditions.
Old 09-01-2006, 08:36 PM   #153
rmdhawaii,
Thanks, I know the pinions are silghtly worn, but I tried again today. I put a dab of red locktite and it seem to do the trick, just hope I can loosen it now.
Maybe another factor was that when testing today, I heard a little noise high pitched, like a whistle. I stopped running, engine was still amazing. Got it home and took it apart, nothing I could see wrong inside. Then I played with the clutch. Bingo, blew the small clutchbearing apart. Now I feel a whole lot better.
Heres another question, at about what intervals are you changing the conrods. I have over a gal in it now.
Charlie
CHUCKMANDO is offline   Reply With Quote
Old 09-01-2006, 10:08 PM   #154
rmdhawaii,
Thanks!
reecek is offline   Reply With Quote
Old 09-02-2006, 12:49 AM   #155
rmdhawaii's Avatar
Charlie: Not sure about the conrod. I've put about 3/4 gallon through the engine so far. I may just wait until it goes to find out.
reecek:
Old 09-02-2006, 12:50 AM   #156
rmdhawaii's Avatar
Old 09-20-2006, 07:57 AM   #157
Is anybody knows what kind of updated piston and liner was using Cyrul at the world's??
Is it always a Nikasil liner or a new ABC piston/liner kit ??
romuald31 is offline   Reply With Quote
Old 09-20-2006, 08:21 AM   #158
Nano's Avatar
Well as for the piston/liner, the conrod will generally not have to be changed for a long long time^^. The only part that needs to be replaced for sure is the rear bearing every 10 hours. The rest will depend on how you use and maintain your motor.
You state you took apart your motor, I hope you took great care while putting it together again. It's crucial that the head is tightened evenly on the case.
Nano
Nano is offline   Reply With Quote
Old 09-20-2006, 08:33 AM   #159
Nano's Avatar
For sure it wasn't ABC that was used, we have developped a working system using Nikasil plating for our liner and we know why^^
As for different timings on the ports, I will have to check out with the crew when they come back from Australia.
Old 09-20-2006, 02:46 PM   #160
rmdhawaii's Avatar
You're kidding me, right? First time I've heard of this. When did this info come to light?
Old 09-20-2006, 06:56 PM   #161
They were definately running different port timing in Australia.
Rody is offline   Reply With Quote
Old 09-21-2006, 05:40 AM   #162
Nano's Avatar
Well if you didn't know, now you do^^. It's kind of difficult to say exactly how long parts will last because there are too many factors that will affect the lifespan of the parts. So depending on how and with what fuel you run your engine your mileage will vary. But this is what has been done by the CRF team till now, they also change the conrod at the same time just for safety.
Remember the piston does not touch the cylinder so you will not get the usual piston/liner wear you get with other engines. Obviously over time engine parts will wear out but it should take a long time.
Old 09-21-2006, 05:44 AM   #163
Nano's Avatar
I spoke to Didier (one of the two guys from Team Orion/CRF at the track) this morning and they did test/use new ports configuration. We are going to get all the info together and see what evolutions we will bring to the engine if needed.
Anyhow, it seems that a lot of people were impressed with Josh's engine performance. Remember that Josh basically was running an EFRA legal engine, versus the competition that were running IFMAR legal engines which are less restricted.
Old 09-21-2006, 06:07 AM   #164
Are you saying there are 2 version of this motor??? One EFRA and one IFMAR??? IFMAR less restrictive... Your motor from the crank to the sleeve had more things going on then any other motor that ran at the worlds... I believe that was one reason for the protest... I'm happy to see Josh Cyrul do well with the motor... I really want to know what crank mod did Team Orion do to the CRF... and you say it's was still with EFRA limits... Hey, inquiring minds want to know.
RC_Alan
rc_alan is offline   Reply With Quote
Old 09-21-2006, 06:57 AM   #165
Dynamite's Avatar
Send a message via MSN to Dynamite
i'm pretty sure they were protesting the expansion hole and slits at the bottom of the liner under the ruling of max 4 ports including exhaust port. obviously the protest must of been upheld since josh ran the motor... and what a rocket!
it almost looked like it kicked into 3rd gear 3/4 of the way down the back straight... although it did flame out a few times in the final, which is a little worrying.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
TEAM ORION .12 CRF WASP SERPENT CURACAO R/C Items: For Sale/Trade 0 03-08-2007 01:01 PM
****Team Orion CRF Wasp Rev .12**** polesitter61 R/C Items: For Sale/Trade 3 11-29-2006 03:52 PM
Team Orion WASP CRF .12 Z00M Australia For Sale/Trade 2 10-17-2006 04:33 AM
team orion wasp rev MAVICXXX Malaysian R/C Racers 31 09-19-2006 09:18 PM
Team Orion Wasp .12 HaLo_UsMc R/C Items: For Sale/Trade 6 03-09-2005 10:41 AM
