Team Orion Wasp REV
#166
Originally Posted by Nano
Remember that Josh basically was running an EFRA legal engine, versus the competition that were running IFMAR legal engines which are less restricted.
1) Max. 7mm bore in crank
2) End of crankhole near backplate, can have a max. rounding of 0.5mm, (so no turboscoop going into this hole)
On the other hand if Team Orion was running EFRA legal engines, tells me 2 things:
1) they were so convinced of them selves, that they would win the worlds even with an EFRA legal engine (But then just in case would also have an IFMAR legal version ready)
2) they were so stupid NOT to use an IFMAR legal engine, which now even might have cost them the title.....
#167
Another interesting thing to note was that Josh was running a Sirio 2611 pipe
M7H: I walked around the pits and managed to see 1 Mega ZX12!! Thats right, just 1. Serpent were running Mainly MaxPower SL3 WC, and a few MF's. What are your thoughts on this?
#168
Originally Posted by M7H
The only regulations EFRA has and IFMAR doesn't are these 2:
The crankshaft that was used was the same 6mm crankshaft you get when you buy the engine. Modified cranks were tested but they made the car difficult to handle because of excessive power.
#169
My point was that these 2 EFRA requirements are considered as restrictions (made to limit performance and/or cost of the engine).
I'm not a newbie on this... in fact if you can search on the Team Orion forums, you can see some posts made by me regarding this. EFRA sometimes should look farther than their own belly and try to being in the same line of other blocks (ROAR, FAMAR, FEMCA,....)
#172
Originally Posted by Corse-R
.....trying to 'equalize' or at least to slow some costs associated with racing. Many years ago was the biggest stupidity with the infamous 12 turn limit on Touring cars who opened the doomed 'search for the n milivolt more on the batts', later was the 7mm crank bore and the 'turbo scoop' that in few days, deemed illegal almost all the .12 engines that were on the market (and of course, the need of buying new engines).
that's indeed not really lowering the costs.........
Luckily I drive 1/8 scale, which is an "outlaw" class.......
#173
My point was that these 2 EFRA requirements are considered as restrictions (made to limit performance and/or cost of the engine). Because of it's new technology the CRF engine is not restricted by these requirements. It does not need crankshafts with 7mm+ bore and funky turboscoops to be the fastest engine on the track even when competing with engines which are not EFRA legal.
Originally Posted by ziggy12345
I asked if the CRF is EFRA and BRCA legal and Team Orion confirmed it is. I asked how this could be when the hole in the crank is more than 7mm but no response. They are using them at national level here and in Europe so guess they are legal.
I run mine on 25% Nitro as it didnt like 16% but not at nationals.
#175
A diameter is always measured at 90° of two parallel lines from a hole (tube). You can also try to insert a gauge of 7mm, if it goes in it means it is bigger than 7mm if you can^t insert it, it is smaller than the gauge. The CRF engine has a 6mm hole.
#176
I spoke to Didier (one of the two guys from Team Orion/CRF at the track) this morning and they did test/use new ports configuration. We are going to get all the info together and see what evolutions we will bring to the engine if needed.
Thanks Nano!
#177
Originally Posted by rmdhawaii
So what does all of this testing mean to the consumer and those of us that already have the engine? If it's decided that the engine runs better with a different port configuration, are we going to get new parts or would it be something that we would have to purchase?
Thanks Nano!
Thanks Nano!
#179
If they turn it into an option part, then that would be fine.
If they change what's sold NIB, I would have an issue with that.
#180
Originally Posted by TomB
well guess what if/when they release the new liner with the less extreme ports it will probably be a NIB part...so there's gonna be problems down in "hawaii" i'm guessing
The Cyl port timing is actually quite tame at around 165 ex and 110 transfer. This is much milder than most current top level engines on the market many around 175 ex and 125 transfer.
But also keep in mind that most of these 'other' engines have crank timing of around 210 deg.
BK
