Old 08-15-2005, 08:11 AM   #661
Ok so has any one here run the .12 tz with the .1mm head shim removed on 30%?
ATXPro4 is offline   Reply With Quote
Old 08-15-2005, 06:46 PM   #662
Sofast-NT's Avatar
I use 20% with the .1mm shim.I don't think 30% with a .1mm shim would work to good.It could also hurt your fuel mileage.
Sofast-NT is offline   Reply With Quote
Old 08-19-2005, 07:28 PM   #663
jeff1's Avatar
Post
Hello, which method of break-in are you using guys? I have seen a lot of methods, like Josh Cyrul, WOT, RB Engines, and the OS method but I cant decide which I use. Can you tell yours experiences?
Byron 2000 20% nitro with 12% oil is a good fuel for race? Or it is better to change to a fuel with 9% of oil?
jeff1 is offline   Reply With Quote
Old 08-22-2005, 10:54 AM   #664
rc_king1's Avatar
What is the difference between L52 and L70 pipes? Mainly, can some explain the differences between the following:
OSMG2970 72103051 O.S. Tuned Pipe T-1040 L52 Left Side Optional
OSMG2974 72103071 O.S. Tuned Pipe T-1040 L70 Left Side Optional
OSMG2979 72106310 O.S. Tuned Pipe T-1040SC L52 Left Side Optional
OSMG2608 72106400 O.S. Manifold M1001SC T-1040SC L52 Optional
OSMG2985 72106500 O.S. L52 SC Complete Set One-Piece Pipe Optional
Thank you
rc_king1 is offline   Reply With Quote
Old 08-22-2005, 10:58 AM   #665
rskoncepts's Avatar
Trader Rating: 21 (100%+)
I think L is left side pipe and the number is the tip opening in mm. So the 52 is 5.2mm and legal size. Guys correct me if I'm wrong.
rskoncepts is offline   Reply With Quote
Old 08-22-2005, 11:50 AM   #666
Leo V.'s Avatar
Just to let you all know how good this motor is.
I've been consistently pitting at 6 minutes, the motor now has two big races under it, and it's still tight.
Leo V. is offline   Reply With Quote
Old 08-22-2005, 05:54 PM   #667
Trader Rating: 13 (93%+)
Default os pipe
hey guys
i have the os pipe to suit the fw-05r / ofna cd3 for sale if anyone is interested ?
brand new and never been used, was taken out of the package and had the hard putty put around the tip for strength.
i believe its the t1040 1 piece pipe
mrgsr is offline   Reply With Quote
Old 08-22-2005, 06:52 PM   #668
moot's Avatar
what shimming and glow plug do you guys use with 30%??
moot is offline   Reply With Quote
Old 08-23-2005, 12:23 AM   #669
BoCal,
Just finish my piston and sleve and crankshaft. Just as fast as yours before you post here.
trebronpay is offline   Reply With Quote
Old 08-23-2005, 02:35 AM   #670
freefallmarine's Avatar
Has anybody tried the OS 1040 pipes? I wonder if there's really a diffrence?
freefallmarine is offline   Reply With Quote
Old 08-23-2005, 08:05 AM   #671
How do these engines match up to the RB V12 engines? They're close, price wise, but just curious about the performance between the two? An RB V12 goes for 220 (3 port) where the 5 port version is 249. These prices are from acehardware. I want another engine for my other MTX3, and was considering the OS12 TZ, but if the RB is only 50 bucks more (5 port) and performance & reliability is better, it'd be better to go with the RB.
snowboardgeek1 is offline   Reply With Quote
Old 08-23-2005, 03:24 PM   #672
jeff1's Avatar
Old 08-26-2005, 05:45 AM   #673
Mie3R's Avatar
just follow the manual book if u r not an expert or confuse with so many methods
Mie3R is offline   Reply With Quote
Old 08-26-2005, 10:50 AM   #674
jeff1's Avatar
I am not new to the hobby but new to these methods. I always break-in my engine with my own method, I want to try a new method for more perfomance and Ive seen guys have good expierence with Wot method and Josh Cyrul. I have doubt if this method work good for TZ 12 3P
Sorry, my english is terrible I am learning
Whats mean flames out?
Old 08-26-2005, 11:32 AM   #675
Mie3R's Avatar
i would suggest u follow the os method if durability is concerns. josh cyrul is running on sirio. different engine has slightly diff character. use propeller while break in the engine. tq
