Old 08-26-2005, 12:28 PM   #676
where can i buy parts for this engine
nero1943 is offline   Reply With Quote
Old 08-26-2005, 03:32 PM   #677
moot's Avatar
i used the WOT method and have just used my 8th litre of 30%. still has heaps of compression and seems to be making more power
my jp would have blown the rod by now
moot is offline   Reply With Quote
Old 08-26-2005, 10:49 PM   #678
really 8th litre of 30%???
Old 08-26-2005, 11:17 PM   #679
freefallmarine's Avatar
Just started breaking the new TZ 3port in on my RRR wc. man this thing's got some pinch! Im using Josh's wot break-in method with 30% o'donnell fuel but due to 100% heat outside. i decided cut it short and stay indoors today. Can't wait to finish up and school some racer's with my lil ole TZ. My wife's racing a TR 5 port in her MTX3, Is the 3 port TZ suppose to have more power than the old 5 port's?
freefallmarine is offline   Reply With Quote
Old 08-26-2005, 11:30 PM   #680
moot's Avatar
yeah,and i havent been nice to it either
Old 08-26-2005, 11:39 PM   #681
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
freefallmarine- oooh yeah!!! much more!!
Moot- your avatar is definately....unique.
BigDogRacing is offline   Reply With Quote
Old 08-27-2005, 05:03 AM   #682
uaerc's Avatar
I did the 6th tank today on my TZ 05 and boy this thing has some amazing range of power. Its on my Fw05RR with a JPL Turbo pipe - 20% Coolpower Fuel. Engine temps were kept in between 103- 107 C. I did not use my temp in the first run and the temps went to 122C and this car was literally flying... with so much power that my RR was actually running into a tail spin........due to the immense power..
Oh yeah... need to stock up on the conrod =- piston /sleever combos just in case.
uaerc is offline   Reply With Quote
Old 08-27-2005, 09:50 AM   #683
yeah where can I get the piston and sleeve?
Old 08-27-2005, 08:40 PM   #684
jeff1's Avatar
Arrow
http://rc-mushroom.com/product_info....oducts_id=6510
jeff1 is offline   Reply With Quote
Old 08-27-2005, 08:48 PM   #685
jeff1's Avatar
I started my engine and it was very difficult to mantain in idle I am breaking-in. Does anybody now the factory set for idle needle? My are so much close, in the instruction sheet say to keep 0.5mm as default configuration, but how I measure it? I prefer to set the idle by turns in the screw, like HSN
Thanks!
Jeff
Old 08-28-2005, 10:03 AM   #686
Send a message via MSN to pedal2thametal
hi guys.
whats the best optional brand for glowplugs for the tz 3p
i burned trough my first one, and i cant find os glowplus near me.
wil any other brand do?
pedal2thametal is offline   Reply With Quote
Old 08-28-2005, 07:42 PM   #687
Mie3R's Avatar
can use nova or rb glowplug
Mie3R is offline   Reply With Quote
Old 08-29-2005, 12:07 AM   #688
chippy's Avatar
Default Glow Plugs
No for some reason you have to use the OS glow plug
Slightly different taper to the Nova based plugs causing a slight leak around the Glow plug
Havenít tried the McCoy plugs yet
chippy is offline   Reply With Quote
Old 08-29-2005, 12:58 AM   #689
moot's Avatar
i have used novarossi plugs for 8 litres and never had a problem.
Old 08-29-2005, 01:41 AM   #690
Finished breaking in the TZ 3-port today and well, "Holy Crap"! This things got some juice! Break in went very smooth, Had to use foil to keep heat in, But it tunes very well and keep's a great tune like our previous tr's. Big Dog you were right it pulled from my wife's 5-port tr and then some.Im really happy with this motor and caint wait to get about another 1/2 gallon to see if it'll open up some more. It loves 30% and OS P8 plug's. let me know what kind of fuel milage you guy's get. And if you guys use restricter's on your motor's. Thank's. C.
