Like Tree1Likes
Palmaris engine thread
Old 07-13-2004 | 04:25 AM
  #856
kitracer's Avatar
Originally posted by boner
kitracer: I believe I tried leaning the low end to as low as 1 turn from close and show signs of too lean. Well I hope i'll find time today to do more fine tuning on this engine.
boner,
May be too lean on HSN. Try starting from 1 1/2 turn LSN, 4 1/2 turn on HSN.
If anytime your plug coated with fuel, meaning too rich.
Tell us more when u run the engine again. Good luck
kitracer is offline
Old 07-13-2004 | 03:55 PM
  #857
Boner, how many shims are under the button? Or maybe measure them together. It almost sounds like you're overshimmed. Too much fuel in the combustion chamber. Btw, when I used a MT12 carb, i was running the LSN a little over 1 turn out.
Surge is offline
Old 07-13-2004 | 06:19 PM
  #858
boner's Avatar
Just got back from tuning. Surge you are right about shiming, 1 shim makes a lot of different. If I'm in Cali, I'm sure TG777 will kick me in the butt for not listening to him. Somehow the engine doesn't seem to have the acceleration used to have and it like to peak 280F no matter how rich I set on HSN (tried 5 1/2 turn out). Maybe it's because I'm running on a open parking lot + warmer plug. Going to do more tuning tomorrow after I pick up a new fuel bottle, don't you just hated when things are start to working well and fuel bottle decide to tear apart?
boner is offline
Old 07-27-2004 | 10:06 AM
  #859
Default Settings
Hi Guys,
With the experience so far with the PS12 give me your base settings.
I've got a carb from an MT12
Running 3 shims
3 1/2 top
2 bottom
Novarossi No. 6 plug
I can start the engine no problem, it will run steady as long as I keep the glow starter on the plug, when I take it off it dies in 10 secs. It sounds like it is loading up.
I attempted leaning out the bottom end & top but felt I could start doing some harm so I stoped.
I did try a No. 7 plug but it seemed worse.
So what to do . . . . . . .
Thanks in advance
click, dublin is offline
Old 07-27-2004 | 10:24 AM
  #860
Default body for 950R
Edward,
Did Leo like the 1/8 body I painted for him?
TambokGT is offline
Old 07-27-2004 | 11:04 AM
  #861
EdwardN's Avatar
Default Re: Settings
Originally posted by click, dublin
Hi Guys,
Running 3 shims
3 1/2 top
2 bottom
Thanks in advance
Hi Kevin.
It is too reach on the bottom, lean it to 1-1/4-1-1/2, will not harm.
EdwardN is offline
Old 07-27-2004 | 11:06 AM
  #862
EdwardN's Avatar
Default Re: body for 950R
Originally posted by TambokGT
Edward,
Hey, I was thinking you are already gone to San Jose.
Yes , he love it and I already made all holes. just wait for next practice.
Did you tune 21 BRB P/S set ?
See you at RAMS next Sunday
EdwardN is offline
Old 07-27-2004 | 11:10 AM
  #863
boner's Avatar
listen to TG777 he know his stuff. you low end is on rich side and use cold plug this engine like it a lot. my needle setting with mt12 carb:LSN 1 1/2 HSN: 4 1/3 run like a charm (180F)
boner is offline
Old 07-27-2004 | 11:13 AM
  #864
Hi Guys,
Thanks for the replys.
Boner when you say run a colder plug do you mean a 7 instead of a 6 (Novarossi range)
Many Thanks
Old 07-27-2004 | 11:52 AM
  #865
Just ran the engine again with the new settings:
Bottom 1 1/2
Top 4 1/2
Tried a No. 6 & a No. 7 Novarossi plug
Engine will not idle without the glow starter on the plug.
It starts OK but when I take the glow starter off, it dies?
Idle is set high
Any suggestions?
Old 07-27-2004 | 11:59 AM
  #866
EdwardN's Avatar
Bottom 1 1/2
Top 4 1/2
Idle is set high
Any suggestions?
What is ambient temperature now?
Try hotter plug-in Europe if it is cold, #5 might work better on idle.
But still to reach on bottom. Go for 1-1/4
EdwardN is offline
Old 07-27-2004 | 12:26 PM
  #867
How many shims should there be?
I've got 3 shims & was told one was removed before I got the engine, is this correct? Should there be 4?
Temp 11c / 52f
I don't have any no. 5 plugs!! I've never needed them in the last 7 years running .12's.
The engine runs fine with the glow starter on it but now, with the new settings, it cuts out the second I remove it.
I'll try again with a leaner bottom end.
Old 07-27-2004 | 12:28 PM
  #868
Forgot to mention, I'm running 16% nitro, could this have anything to do with shims?
Old 07-27-2004 | 01:02 PM
  #869
Changed bottom to 1 1/4.
Still no difference.
Will have to wait until I get some no.5's.
I find it hard to believe thats this is the problem, but I'll give it a try.
Old 07-27-2004 | 01:19 PM
  #870
boner's Avatar
you have to ask TG777 on head shim. By the way, did you check the temp of your engine when it flood/flame out? It's a pain to tune an engine when it's cold. I probably will put the ignitor on until engine reaches 45+C
boner is offline
