Old 01-23-2004, 11:18 PM   #106
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Default EDWARD
Keep the team motors plain natural color so people can distinguish team drivers from store bought motors.I dont care for red much................Floresent green, now were talking! (ED) Here is the slower avatar!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 01-24-2004, 03:17 AM   #107
EVOLUTION's Avatar
This seems to have become the avatar thread.
EVOLUTION is offline   Reply With Quote
Old 01-24-2004, 05:11 AM   #108
stefan's Avatar
Send a message via AIM to stefan
Originally posted by Pit-racer
No that red is too dull, needs to be more flashy and bright. It's up to you and your son.
That red is anything but dull. The picture doesn't do it justice here.
stefan is offline   Reply With Quote
Old 01-24-2004, 07:58 AM   #109
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I was thinking the same
Old 01-24-2004, 08:00 AM   #110
Pit-racer's Avatar
Back to engines!
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 '17
Pit-racer is offline   Reply With Quote
Old 01-25-2004, 08:19 AM   #111
EdwardN's Avatar
Default Palmaris PS12
Hi guys. Run in engine yesterday with 80 % Methanol and 20 % oil ( ni nitro). Two tanks on bench full open throtle and pretty reach-aprrox 15 K RPM. Then put it on track with the same fuel and run it one more tank. Then Off road gyus came and kick me out-it is their competition day. So we moved to CP.
Switch fuel to Mugen 20 % nitro. Engine was running pretty good but still too tight. Blew glow plug. Tons of bottom end and mid range, but top speed was like modded MR12.
Was running coupl tanks with short braks ( talking to Pat Fox about engines). Every tank is 9 minuts-9 minuts 30 second. It was timed not by me ( was busy to listen engine), it was timed by one of the local respectible racer. Temperature 230 degree.
So conclusion for first day-verry satisfyed0 nothing got broken ( alot of parts my lighter then existing designs), engine has very good bottom and mid range ( most dificult to get), top speed is still chalange-next time will work with gearing and pipe. Had feeling the pipe was way to short ( RD logis one piece).
Open engine last night-still toooooo tight, I relaped it and will play with that next Saturday with Randy's help.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 01-25-2004, 08:38 AM   #112
InitialD's Avatar
Default Re: Palmaris PS12
Ed, good to hear that you got your engine working up and running ! Can't wait to see one running.
Question... If you're looking for top speed high RPM, shouldn't a short pipe like the RDLogic one piece be ideal? A longer pipe would not give better high engine RPM though. Perhaps you have other reasons...
Old 01-25-2004, 09:16 AM   #113
EdwardN's Avatar
Default Re: Re: Palmaris PS12
I can easy get engine running with RD logic pipe ( one piece), but don't want to loose my bottom end which I have now. So this is why I sad it is challange. I can change exhaust timing and will get that top speed which I want to, but it will defenetly impact my botom end, stability ( like Kalashnikov AK47). No I want to get the way arround, come on, just first 7-8 tanks of new design, I need to work on it more. Head shimming, gearing, pipe- I need one more day ( may be today after work for couple hours.
Old 01-25-2004, 09:23 AM   #114
stefan's Avatar
Hi Edward,
great to hear that your initial shake down went good, w/o any broken parts. I think that's all you can ask for at the very firt run.
Question, is it not likely that the engine will have more top end once she's fully broken in?
You say that she's still very tight.
I my experience, they gain a lot of top end when they become a bit looser.
Good luck for your next run..
Old 01-25-2004, 09:26 AM   #115
stefan's Avatar
Oh, btw, myself and a friend ran the first batch of my fuel in 8th scale buggy yesterday.
I have a Picco G1 pro BV in my buggy that always gave me trouble with idle and temp.
Changed only to my fuel yesterday and she ran like a champ.
Steady idle through a full tank, ungodly hp.
My friend also saw a gain in horse power and a drop in temp.
I'm happy
Old 01-25-2004, 09:29 AM   #116
EdwardN's Avatar
Originally posted by stefan
Hi Edward,
Hi Stefan. How is going.
I have suspect the same thing and this is why i did relaped already piston. I don't worry if something missing in performance now at this stage, for me most important is engine parts ( you saw the shaft"s pic), conrod, bearings etc. I was thinking the bottom end will be an issue, top speed it is easiest part to get.
Old 01-25-2004, 09:31 AM   #117
EdwardN's Avatar
I'm happy
I look forward to use that fuel.
Old 01-25-2004, 10:25 AM   #118
tranced's Avatar
what happens when the sleeve gets worn out. how do you replace it if it is 1 piece with the casing ?
tranced is offline   Reply With Quote
Old 01-25-2004, 10:41 AM   #119
Corse-R's Avatar
Seems you've had some success blending your own fuel.... Is a brand new 'Stefan's recipe' or I know it?
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-25-2004, 10:42 AM   #120
modellor's Avatar
Tranced. You simply replace the complete section of the casing/sleeve.
It may sound more strange but if you want power you got to be willing to take on the changes and pay for the goods.
modellor is offline   Reply With Quote
Palmaris PR12 .12 1/10 touring car engine boy2rc R/C Items: For Sale/Trade 0 01-29-2007 09:28 AM
Palmaris Racing EdwardN Monster Trucks 0 11-26-2006 08:56 AM
Palmaris Racing EdwardN Electric Off-Road 0 11-26-2006 08:48 AM
Palmaris PS12 engine for sale boy2rc R/C Items: For Sale/Trade 0 08-10-2005 09:05 AM
Palmaris PS12 for sale boy2rc R/C Items: For Sale/Trade 2 03-16-2005 06:15 PM
