Like Tree195Likes
Novarossi engines thread
Old 03-04-2016 | 02:40 AM
  #5116
Originally Posted by snuvet75
If I were to use Keep on .21 crankcase with Bonito .21 sleeve, would it work? the cases of both must be different but I just wanted to ask. Bonito is 7 ports and keep on 9ports. Everything else is Keep on's.
On road and off road crankshaft timing should be different
kyosho malaysia is offline
Old 03-04-2016 | 12:53 PM
  #5117
snuvet75's Avatar
So you're saying it wouldn't work? The only difference from Keep on is the sleeve. Could you elaborate how the change of sleeve relates to the crankshaft timing when the shaft and case are from Keep On? Thanks.
snuvet75 is offline
Old 03-04-2016 | 01:02 PM
  #5118
Roelof's Avatar
Today's high end offroad engine have a crankshaft timing that does not differ much from onroad.
An offroad P/S set in an onroad will work but due a low port timing you will not have the performance of an onroad.
Roelof is offline
Old 03-04-2016 | 01:20 PM
  #5119
snuvet75's Avatar
Thanks Roelof. Was it Harry? Anyway, again, can you explain how changing sleeve only will affect the crankshaft timing??
snuvet75 is offline
Old 03-04-2016 | 01:54 PM
  #5120
Roelof's Avatar
Changing a sleeve will not change the cranktiming. A large (onroad) cranktiming can deliver high performance but the lower port timings on the offroad sleeve will dim the power and top rpm. Nevertheless with an onroad exhaust trying differen manifolds will give an engine performance in between an onroad and offroad.
Roelof is offline
Old 03-05-2016 | 03:57 AM
  #5121
Roelof wich fuel are you trusting these days with the novas ? i was having good luck with tornado but now they are closing
nick m is offline
Old 03-05-2016 | 04:52 AM
  #5122
Roelof's Avatar
Castor based fuels. The best is Runnertime (now also sold as Tesla fuel) but stuff like MLC and Xceed are also OK
Roelof is offline
Old 03-05-2016 | 06:38 AM
  #5123
thank you
nick m is offline
Old 03-07-2016 | 07:48 AM
  #5124
vivo quevas's Avatar
How much castor per gallon do you add?
vivo quevas is offline
Old 03-10-2016 | 11:06 AM
  #5125
dan_vector's Avatar
If you run fuel like runner time or tesla then you don't 'add' any caster.
If you are running a fuel like Rapicon for example which is 9% synthetic you can add caster up to 11% total oil content. I've done that before when I couldn't get hold of Runner Time while racing in Asia.
dan_vector is offline
Old 03-10-2016 | 12:34 PM
  #5126
Roelof's Avatar
It is wise to test it first in a drinking glass to see if the castor will mix with the fuel. Most of the time it will but you will never know for sure. It would be a shame if you ruin a fresh can of fuel.
Roelof is offline
Old 03-11-2016 | 07:53 AM
  #5127
Thanks for the tip but how much castor do you add to gallon of fuel if it will mix together?
Old 03-12-2016 | 06:20 AM
  #5128
dan_vector's Avatar
You've got to do a bit of maths and work it out depending what the existing blend is and if the can is 1 us gallon or 5 litres etc. In the past I've run Rapicon as I couldn't get anything else which is 9% synthetic oil. I added 80mls of Novarossi castor to it.
Old 03-23-2016 | 05:31 AM
  #5129
Has anyone run the novarossi Mito 7 .21 on road?
What are your thoughts?
mrgsr is offline
Old 04-13-2016 | 12:50 AM
  #5130
JamesHealey's Avatar
The 7C or the 7?
JamesHealey is offline
