Like Tree195Likes
Novarossi engines thread
Old 02-05-2016 | 12:27 PM
  #5086
vivo quevas's Avatar
Originally Posted by dan_vector
I've had both of these and the Mito is better. The VIRTUS to me lacked top end and it didn't hold tune very well particularly the bottom end. I personally didn't like the VIRTUS .12 The Mito is much more stable and the top end is back. Great motor!
Thanks Dan, as always good insights.
I too am leaning toward the Mito and I will be ordering a motor next week. I also took your advise on buying a new piston and sleeve for the Keepon motor I have 17 tanks through it starting move to a race tune.
vivo quevas is offline
Old 02-05-2016 | 12:41 PM
  #5087
YANMAN's Avatar
Originally Posted by vivo quevas
Paolo I have never seen any posting on the performance of a Mito .12. Given a choice Mito or a Vir-Tus which is the better motor to race at the Airtronic's GP in L.A. in your opinion. Or anyone else that has an opinion on these motors.
Everything I have been told the LegendR .12 is better than either the Mito or Vir-Tus. I was told the Mito lacks bottom end.
YANMAN is offline
Old 02-05-2016 | 12:56 PM
  #5088
Great news but I guess I missed out as not in stock at the moment
http://www.serpentamerica.com/shop/home.php?cat=82
BTW, you can take advantage of Novarossi sale going on. 15% discount. use the NOVA15 code
Paolo M is offline
Old 02-05-2016 | 01:10 PM
  #5089
dan_vector's Avatar
Thanks.
dan_vector is offline
Old 02-05-2016 | 02:02 PM
  #5090
desotoracing is offline
Old 02-07-2016 | 06:36 PM
  #5091
Need to know the part # for a carb rebuild kit for a flash12 or a keepon motor.
Old 02-07-2016 | 07:28 PM
  #5092
dan_vector's Avatar
If you are asking for the o-rings for the carb then I don't think I've seen 'rebuild kits' for the different NR carbs. I just follow the exploded diagrams and order the orings seperately:
http://www.novarossi.it/2012/images/.../KEEP-ON12.pdf
http://www.novarossi.it/2012/images/...FLASH12-PT.pdf
Old 02-15-2016 | 07:13 AM
  #5093
Can someone tell me something about this motor.....
It's a Novarossi ....it says "2000 3.5" ....
I was told that it was a Jp modified but it doesn't say "Jp" anywhere on it.....but it does have a serial # engraved into it.....
Any info would be appreciated!!
Here are a couple of pics....
NickTheGreek is offline
Old 02-15-2016 | 07:16 AM
  #5094
Old 02-15-2016 | 07:18 AM
  #5095
Old 02-15-2016 | 07:46 AM
  #5096
Roelof's Avatar
That is old!
The race in a Nova2000 crankcase. From what I know it has a square bore x stroke, so 16.4 x 16.4. It is from the begin 90's I think arround 1994. It is a 7 port engine.
And probably it has a 4.9mm crankpin while most onroad models today are 5mm.
Roelof is offline
Old 02-15-2016 | 08:44 AM
  #5097
Thanks.....
Is there a way of knowing exactly what that serial # is???
.......This is what I want to throw it in....
Old 02-15-2016 | 01:33 PM
  #5098
Scott B's Avatar
Originally Posted by desotoracing
Joaquin, you may want to let a Novarossi know they should include a 7mm Venturi since that's the largest ROAR allows for GT8. My motor came with three very nice alumn Venturi's but all to large.
Scott B is offline
Old 02-16-2016 | 06:52 PM
  #5099
Dan or anyone else I received my Mito motor, and started the break in pdocess.
What I noticed is this motor has a lot less pinch then my keepon or even my legend motor did when those motors were new. The mito has less pinch then my keepon with a half gallon has been run through it.
So with less pinch does that speed the break in process up?
Old 02-17-2016 | 03:23 AM
  #5100
dan_vector's Avatar
It just means you got a good one keep the running process the same as you've always done. Take it steady but make sure you are getting temperature in the engine each run. It doesn't need to be crazy rich just enough to keep 10-15 degrees off the top end at this point.
You'll know when its properly run in. The engine will stop going rich by itself and run consistently for the whole tank.
