Novarossi engines thread
#4936
#4938
I have the Hudy one. The Novarossi one is very good probably the best but a bit expensive. It's one of those things that as a nitro racer is a really useful thing to have in your kit. I've even changed bearings trackside at a push with mine which kept me racing my best engine on the day...
#4940
Look.the best of two types is heat a bit the case and then use the puller.donot use it in cold metals.if you change bearings many times,the case been sized step by step. Reasulting in lost tolerance.
#4941
I was on the novarossi site looking at the specs for the new mito 12 engine. In the exploded view there are 2 different part numbers for the rear bearing, 16607 and 16608. The 08 is a steel bearing and 07 ceramic. If I'm not mistaken, the keep on 12 uses the same rear bearing in ceramic. Now my question, are the rear bearings in the keep on the same as the mito? Do they come steel all of a sudden? Or did they always come steel and I assumed they didn't? Sorry that's more than 1 question.
#4942
#4944
Looks like Collari is working on the Mito 9 as well.
http://www.modellismocollari.com/sho..._product=30428
#4945
#4946
Cheaper to buy Novarossi engines from www.rcmushroom.com even with shipping charges, they have the latest engines available in stock
#4947
Check with novarossi america. [email protected].
#4949
#4950
your quite wrong,if you go rex-usa.com,they have novarossi REX and novaroosi TOP engins as well as all novarossi parts and acc. for all on and off road engine. You will not beat there price and service.same day shipping or you can call and talk to Buddy anytime.
195Likes
