Like Tree195Likes
Novarossi engines thread
Old 05-08-2015 | 05:25 PM
  #4966
I have a brand new CX15 but have nothing to put it in. All my cars are 1/7 and 1/8 scale. Can someone educate me on this engine? when I bought my Scorpion XXL it was at the bottom of the box.
BernieB is offline
Old 05-10-2015 | 06:12 PM
  #4967
Anyone know someone that's interested in an engine like this? If I could sell it to someone who will actually put it to use that would be great.
BernieB is offline
Old 05-11-2015 | 03:39 AM
  #4968
JamesHealey's Avatar
.15 are legal race engines for the 220mm Sports GT class in the UK maybe someone here would have it?
JamesHealey is offline
Old 05-11-2015 | 04:49 PM
  #4969
If anyone wants to make an offer on it I will get a spot quote on the shipping. Message me for details.
BernieB is offline
Old 05-22-2015 | 03:45 AM
  #4970
Default MitoC
Is the new MitoC a step backwards?
jtrmx250 is offline
Old 05-22-2015 | 04:00 AM
  #4971
Roelof's Avatar
It depends.... The MitoC is Flash based.
- 14.5mm crankshaft
- normal 14.5 x 26 bearing
- no offset carburator mounting
- bore x stroke: 16.2 x 16.8
Most say the xtra long stroke engines do perform well but in the hands of most drivers I think the MitoC is nothing different. I think they will be the cheaper engines and for sure cheaper in maintenance.
Roelof is offline
Old 05-31-2015 | 03:35 PM
  #4972
need to change the rear bearing in my keep on 12. Is there a special adapter for the Hudy bearing puller?
JOE SI is offline
Old 06-01-2015 | 06:42 AM
  #4973
I use KM bearing puller
kyosho malaysia is offline
Old 06-03-2015 | 02:57 AM
  #4974
No, it's just a different design philosophy, I don't think there is any real performance disadvantage in the slightly shorter stroke and centralized carb.
I think this is what drivers want from Novarossi, an engine that is cheap to maintain, doesnt use the odd "patented" off set bearing, and is fast.
Novarossi are probably just listening to their customers a bit more, which isn't a bad thing is it? Nobody wants to have to use a $100 bearing in the rear you can only source from one manufacturer.
RB did the same with the CXR SLS9 V2 went back to the standard ceramic bearings.
Old 06-20-2015 | 10:28 AM
  #4975
endurohero's Avatar
Does anyone know of a good source for a piston/sleeve/rod combo for a novarossi 353 race .12 engine?
endurohero is offline
Old 07-09-2015 | 05:57 PM
  #4976
Default New n needs help
Hi,
I have 3 novarossi engines, n want to know which will give me more power or performance ( only using mugen for bashing at the moment)
Ison .12
353 .12
12-3 sct
All engines are stock
Will appreciate any info. Thanks
Will smith is offline
Old 07-09-2015 | 09:50 PM
  #4977
Can someone please tell me the difference between the virtus .12 and the mito .12?
From what i can by comparing parts is the head/button and crankcase are different due to the mito only having 4 engine screws and the virtus 6.
also is there a tuned version or are the only versions steel bearing or ceramic bearing?
Thank you
mrgsr is offline
Old 07-10-2015 | 12:09 AM
  #4978
WildManDriving's Avatar
Originally Posted by Will smith
Hi,
Ison .12
353 .12
12-3 sct
There all very much the same engine so it will come down to which is in the best condition.
WildManDriving is offline
Old 07-10-2015 | 03:31 AM
  #4979
Cheers, bout to race bunch of mates using 4tecs, and various .18 powered 10th scale on road cars,
Just bashing in a huge car park
Old 07-14-2015 | 09:36 AM
  #4980
Oso787's Avatar
Roelof,
Are there any timing differences in the sleeve between the Virtus 21 and the Mito 21?
Oso787 is offline
