Like Tree195Likes
Novarossi engines thread
Old 06-29-2018 | 04:49 AM
  #5716
ralphierace13's Avatar
[QUOTE=Roelof;15253495]Yes, Novarossi does set a tight head clearance not giving enough room to set the tuning on the lean side if you want to. For sure when running long straights it can be harmfull for the glowplug.[/QUOTE
did you get to play with this new one yet? wondering what the changes are from the mito ?
ralphierace13 is offline
Old 06-29-2018 | 05:11 AM
  #5717
Roelof's Avatar
Nope, a fellow clubmember has bought 2 so maybe I can get one to meassure.
Roelof is offline
Old 06-29-2018 | 09:44 AM
  #5718
Originally Posted by ralphierace13
thanks dj, sorry one last question, we don't often get you on here so we need to pick your brain as much as possible !! lol
dj you went with the 6 fin manifold. I know the track was pretty open and a lot on power so what were you looking for with the long manifold, better bottom, med, top,overall power, or better run time.... thanks again
I used the medium header cause it gave me better mileage and better mid range power. The short header was more rpm pull, but less infield power. It was also more sensitive on the tune. I tried them both.
DJ
picco007 and YBSLOW like this.
dj apolaro is offline
Old 06-29-2018 | 11:29 AM
  #5719
GrandeGixxer's Avatar
How long do the ceramic bearings in the .12 motors last?
thanks
GrandeGixxer is offline
Old 07-02-2018 | 04:26 PM
  #5720
snuvet75's Avatar
From I recall, R4 and R7 con rods are interchangeable, no?
snuvet75 is offline
Old 07-02-2018 | 09:55 PM
  #5721
Roelof's Avatar
Yes, R is the mark for the dimensions and the number is the model version.
snuvet75 likes this.
Roelof is offline
Old 07-11-2018 | 12:48 AM
  #5722
Stusdal's Avatar
I tried to replace bearings in my mito .21. The rear bearing I replaced with a steel bearing, 16001. However I seems to be to wide, as the crankshaft don’t align with the groove and I can’t get the rod in.
I dont have the bearing I removed with me, so I can’t compare them now, but the manual says 16001 is correct. It should fit right?
Stusdal is offline
Old 07-11-2018 | 01:13 AM
  #5723
Roelof's Avatar
Do you have a normal Mito or a C-version?
Normal Mito:
http://www.novarossi.it/2012/images/.../MITO-9-ON.pdf
C-version:
http://www.novarossi.it/2012/images/...MITO-9-ONC.pdf
The difference is the dam inside the crankcase that needs a smaller inner race to fit.
Roelof is offline
Old 07-11-2018 | 03:50 AM
  #5724
Stusdal's Avatar
I’m not sure, got it used with the car, no box. 16001 clearly doesn’t fit so it’s likely I have the other one. I’ll order a 16007.
Thanks for the help.
Novarossi - why keep it simple
Stusdal is offline
Old 07-11-2018 | 05:42 AM
  #5725
Roelof's Avatar
There are no differenses in dimensions between the 2 bearings
Maybe you have a wrong head or the information is wrong.
An old topic of me.
Placing cheap "normal" bearings in a Virtus
You must see it on the old bearing that the inner ring is at one side smaller than the outside ring, or else you can see it in the crankcase that around the hole there is a dam.
If that is the case you need bearing 16006
Roelof is offline
Old 07-14-2018 | 03:49 AM
  #5726
Stusdal's Avatar
Thank you! Is there no steel version of the 16006?
edit: looks like I can use 16009 - https://store.novarossi.it/product/o145x26x57x47mm/
Stusdal is offline
Old 07-14-2018 | 05:01 AM
  #5727
Roelof's Avatar
Here a good view of what they have done with these engines
Roelof is offline
Old 07-19-2018 | 08:29 AM
  #5728
British Menace's Avatar
A quick random question here.
What plugs to use for a Mito.12 Ceramic.?
Thanks for any help here.
Regards
BM
British Menace is offline
Old 07-20-2018 | 05:07 PM
  #5729
Usually a 6. I had to go to a 7 last weekend due to high temps and to help with run time.
British Menace likes this.
Old 07-21-2018 | 07:25 AM
  #5730
Ok. Thank you GrandGixxer. I appreciate the answer.
Regards
BM
