Like Tree195Likes
Novarossi engines thread
Old 07-14-2015 | 11:07 AM
  #4981
Roelof's Avatar
Never had one of them in my hands so I cannot tell. I do know that even 2 same engines from Novarossi but from different production dates can have different timings.
Roelof is offline
Old 07-15-2015 | 02:28 AM
  #4982
JamesHealey's Avatar
Saying that most of the variance I've encountered in Novarossi engine timings tends to be on the crank shaft not the sleeve.
You tend to find the transfer ports close at 115 degree before TDC, and the exhaust port 88 degrees before TDC on most Novarossi designs, occasionally the exhaust port will be a few degrees higher on 'tuned' versions.
The crankshaft opening tends to be 33-35 degrees after BDC and the closing tends to be around 62-64 degrees after TDC this is where you get the most variance in my experience.
JamesHealey is offline
Old 07-15-2015 | 05:39 AM
  #4983
Roelof's Avatar
Intake is always at 65 degrees from BDC (your 115), exhaust at 92 ? Most of todays engines are at 93-95 degrees from BDC, even the N21-5T is at 93 degrees
The 14.5mm crank is indeed arround 35/64 but a 1 degree difference will make a difference on the track or just the feeling how it response.
I personally do not believe in the special (high cost) main bearing which seems it is not used in the Mito-C models althoug Novarossi wants you to believe it.
All I know if you buy the most latest and expensive engine you will get the fastest engine. Anything older or cheaper is configured with lower timings. It will not say the cheaper/older engines are bad, they can even perform better in the hands of a less experenced driver because lower timings will give a easy tuning and a better driveabillity.
Roelof is offline
Old 07-15-2015 | 02:35 PM
  #4984
You've measured more engines than I have so you're probably right! I've only really measured RB stuff which maybe timed a bit lower than Novarossi, I've only just made the switch to Nova as you know! I just timed a new Ison .21 and its sleeve is 97/65 and the crank is 41/62 or something similar I can't quite remember off the top of my head, but it's the crank shaft timing that's the limiting factor in this engine, stilk very quick though! And great useable power band!
Old 07-17-2015 | 06:26 PM
  #4985
I needed to change my rod, but instead changed to a new crank. When I changed the crank the pin on the crank took away the play in the rod. There wasn't much play, but now it's gone. Should I still change the rod? or will it be same as changing the rod on the old crank?
JOE SI is offline
Old 07-17-2015 | 08:10 PM
  #4986
Talking SPECS ON STOCK NOVI SERPEANT NITRO 1/8 SCALE .21
WHATS RPM RANGE AND HOW MUCH HP ON NITRO MOTOR FROM SERfPEANT 1/8 RTR
chief19fs is offline
Old 07-18-2015 | 01:25 AM
  #4987
Roelof's Avatar
The play on a fresh Novarossi engine is 0.02mm. 5mm on the rod and 4.98 on the crakpin. It is wise to run a tank with a slight rich adjustment so the first surface roughness is taken away.
On the telemetry my JP 35+ did reach just over 46.000 rpm. Manufacturers are saying 2.7hp in the specs but I believe on a dyno it is about 2hp max.
Roelof is offline
Old 07-18-2015 | 09:02 AM
  #4988
THANK YOU I HAVE ONE ON MY GT2 AND WAS WONDERING WHAT SPECS WAS..
Old 07-19-2015 | 02:42 PM
  #4989
Sorry, not sure if you got what I meant.
Instead of changing to a new rod, I changed to a brand new crank I had sitting around. It took the play away from in the crank. Should I also change the rod?
JOE SI is offline
Old 07-19-2015 | 02:44 PM
  #4990
Roelof,
What exactly are those measurements for?
JOE SI is offline
Old 07-26-2015 | 08:53 AM
  #4991
ChadB.'s Avatar
What are people's impression on the Mito .12 motor? What about runtime? I currently have the Keep-On .12 and it has been treating pretty well, but I am looking to possibly upgrade it.
ChadB. is offline
Old 07-26-2015 | 10:22 AM
  #4992
Roelof's Avatar
Roelof,
With Novarossi .21 engines a fresh crankpin is 4.98mm and a fresh conrod has a 5.00mm hole. It is meassureable with a digital caliper. And measure on several positions arround because the wear is not equal round.
Roelof is offline
Old 08-09-2015 | 05:20 PM
  #4993
I have a P5 Engine, what Pipe do I want to use for this engine with my Mugen MGT7 for more top end.
wichitafc98 is offline
Old 08-10-2015 | 11:30 AM
  #4994
Grinder's Avatar
The Mito .12 is a great engine. Runtime is good, 5 minutes is not a problem on 16%, or 25% nitro. The Mito is smoother than the keepon.
Grinder is offline
Old 08-10-2015 | 11:37 AM
  #4995
Grinder's Avatar
Novarossi 2015
Novarossi 2052
Novarossi 9886
These are all good pipes for GT
Grinder is offline
