Like Tree195Likes
Novarossi engines thread
Old 09-24-2015 | 07:31 AM
  #5011
Originally Posted by Jsgb4.1
Will I have any issues running an OS p7 turbo plug in my nova 5p ?
I think that the OS thread is different than the Nova thread on plug. It might strip It might have a different height on the plug. I try to always run plugs of the engine.
wichitafc98 is offline
Old 09-25-2015 | 12:26 AM
  #5012
I start use os plug in nova engine for few month already, feel good and even reliable than nova plug
kyosho malaysia is offline
Old 09-25-2015 | 04:22 AM
  #5013
ralphierace13's Avatar
nova has brand new plugs out now different design I used them last weekend and they seem real good now!!
ralphierace13 is offline
Old 09-25-2015 | 04:29 AM
  #5014
Nova and OS glow plugs have different taper. When you use an OS glow plug on a Nova engine you will deform the button head then you should stay with them without returning to Nova plugs.
danyvw is offline
Old 09-25-2015 | 08:22 AM
  #5015
yes,this is what i did
Old 09-25-2015 | 02:32 PM
  #5016
3 years ago I had this same question. My lhs didn't have nova plugs, only O.S. I bought OS 6 plugs. When the time came to use one it didn't go in as smooth as a nova plug, but went in without hurting the head. I've been using OS plugs in my .12 engines since. Another time I didn't have an extra plug and needed one. I asked someone for one, he was running a novarossi, and he handed me an OS plug. At that point I felt a lot better using the OS
JOE SI is offline
Old 10-02-2015 | 01:04 PM
  #5017
Default Mito 9ONC front bearing
According to Novarossi the front bearings from the Mito 9ONC are the 17008 (steel) or the 17013 (ceramic) which are the same bearings as the Flash Rally. These bearings are 7x19x5mm.
It is possible to replace those bearing with a "regular size" front bearings 7x19x6 ????
danyvw is offline
Old 10-02-2015 | 01:35 PM
  #5018
Roelof's Avatar
nope unless you have the machines to grind off 1 mm of the bearing races.
Roelof is offline
Old 10-02-2015 | 02:04 PM
  #5019
Thanks Roelof. That makes the onroad Mito a very singular engine referring to bearings. The 9ON has the "special reduced inner ring" rear bearing and the 9ONC has an special front bearing. I was thinking on getting one and was comparing both engines but maintenance on any of them wont be cheap. Why Novarossi has to do this? Thinking twice before buying the Mito 9
danyvw is offline
Old 10-02-2015 | 11:48 PM
  #5020
so....buy PT
Old 10-03-2015 | 01:12 AM
  #5021
Roelof's Avatar
Buy a lathe
http://www.rctech.net/forum/onroad-n...gs-virtus.html
Roelof is offline
Old 10-03-2015 | 02:57 AM
  #5022
so....buy PT
Thank you guys but after thinking about it I didn't buy a PT or a lathe. I bought an engine from another brand.
danyvw is offline
Old 10-15-2015 | 12:42 AM
  #5023
kyosho28 is offline
Old 10-15-2015 | 06:46 AM
  #5024
7 port or 9 port?
Is there a noticeable difference between the 2?
JOE SI is offline
Old 10-15-2015 | 07:14 AM
  #5025
Roelof's Avatar
Commercial seen must be the more expensive 9 port configured faster.
Roelof is offline
