Like Tree195Likes
Novarossi engines thread
Old 11-07-2018 | 09:51 AM
  #5761
Originally Posted by 1/8 IC Fan
Anyone running the new Mephisto that has also run the Ison? How do they compare?
I ran the Mephisto during practice for the GLC and then all the club races after. I also ran the ISON previous years on the same track. The ISON gave me tremendous mileage and a lot of torque around that layout. I ran my all time best runs on that layout with the ISON in 2015. The Mephisto uses slightly more fuel, but has a little more torque than the ISON. I am currently burning the wheels off the car with it. Been working on clutch setups to reduce tire wear. Been close to holding my own against the GSR2.7 which is a derivative of the OS 2103. Used the medium header on the Mephisto and the short header on the ISON. Used 2015 pipe and Byron's 25%WC fuel on all three engines mentioned here. Hope that helps.
davidl is offline
Old 11-08-2018 | 04:17 AM
  #5762
1/8 IC Fan's Avatar
Thank you for the insight. much appreciated.
Guess ill run the ISON a bit more until next year perhaps.
1/8 IC Fan is offline
Old 11-08-2018 | 10:30 AM
  #5763
Originally Posted by thefuzzclub
InitialD,
The clutch is fine, no problem. Cold plug? could be, let me also try, nitro is trinity 20%.
I have another rs12s5 engine in my ntc3 using plug 6 and 20% fuel but no problem in idling. But then again, the crankshaft is the
original one.
has it been released and any test result about this engine?
zinarojt is offline
Old 11-27-2018 | 09:07 PM
  #5764
banana rt's Avatar
how many nitro and oil percentage u guys now running, with stock head shim.
any advice will appreciate
banana rt is offline
Old 11-29-2018 | 02:25 AM
  #5765
GREGORY!'s Avatar
Does anyone have any info about the new mephisto .12 from Novarossi?
GREGORY! is offline
Old 11-29-2018 | 05:31 AM
  #5766
am
Yes.
am is offline
Old 11-30-2018 | 08:53 PM
  #5767
chromie's Avatar
The new .12 will be a mephisto?
chromie is offline
Old 12-01-2018 | 04:46 AM
  #5768
I think yes.
Because there's already 21 off-on Mephisto.
Pedro Jesus is offline
Old 12-04-2018 | 11:23 AM
  #5769
Novarossi Mephisto .12
MEPHISTO.12 On Road Nitro Engine - NOVAROSSI - NOVAROSSI WORLD
Old 01-15-2019 | 10:12 PM
  #5770
wkloppen's Avatar
Default Flash .21 PT/A
Hello guys,
Bought 2 .brand new 21 Flashes for € 358 including shipping ( $ 314,-). A couple of simple questions for the experienced expert:
* Does the 07009 (R7) conrod fit? It now has the 07006 (R4). I'm pretty sure it does but just checking
* I have to measure up the timings on the crank and ports yet and will post it overhere but does anybody have some values for me upfront? ie: crank timing mod? For example oepning @ 32 after BDC and closing @ 71 after TDC.
* Any other tips? I see the main bearing is an 11 ball ceramic standard 14.5 x 26 x 6 bearing which you can buy anywhere for little. My personal favour is Freerun on Alieexpress
You can also clearly see the booster port fanges in the sleeve which the ISON for instance doesn't have...
thx in advance
wkloppen is offline
Old 01-15-2019 | 11:07 PM
  #5771
Roelof's Avatar
1) I told you last Sunday
2) I hinted it on yout 1/8 FB post about a simulair engine, although I expect that this is a same engine in timings.
3) Hmmmmm.....
Roelof is offline
Old 01-15-2019 | 11:14 PM
  #5772
wkloppen's Avatar
3) Hmmmmm.....
Yes you did
wkloppen is offline
Old 02-05-2019 | 04:43 AM
  #5773
Default Novarossi .12 Mito Wc "limited edition"
Hello!
Does anybody know the difference between the usual Mito Wc and the Limited Edition?
It is written on the cooling head of it also.
Many thanks in advance!
KR.
Simon
SimonRc1990 is offline
Old 02-21-2019 | 01:32 AM
  #5774
shiston's Avatar
Hi,
Is the 07601 conrod interchangeable with the 07604 for the .12 engines?
cheers
shiston is offline
Old 02-21-2019 | 07:46 AM
  #5775
I'm using Mito 12 WC with Hipex 2669 pipe and medium (30mm) manifold. Is there any sense to switch to Novarossi pipe 2660 and 41616 manifold?
B.S. is offline
