Like Tree195Likes
Novarossi engines thread
Old 12-09-2015 | 08:23 AM
  #5041
Originally Posted by Roelof
The Mito 9C is just a Flash based engine and I believe Kurzbuch did win the worlds with this engine.
yes i show the description at his car set up indeed Kurzbuch was running a mito 9 c ,so if he choose using that one instead of the other mito 9 on there must be a reason ,i dont now also if it was a sold as it is mito 9c or a special mod engine.
nick m is offline
Old 12-09-2015 | 09:56 AM
  #5042
Roelof's Avatar
Do not know why but do see the normal Mito on sale everywhere so something is going on. To me it is proof that special bearings, an xtra long stroke and an offset carb is not needed to go fast and I hope that the guys who think that the higher the price and technology is garanteed for faster laptimes do see it also.
I think (and hope) Novarossi has seen this too to go back and focus on the real things that makes an engine instead of trying to be different with different (patented) parts.
Roelof is offline
Old 12-09-2015 | 10:12 AM
  #5043
Oso787's Avatar
I am not sure about on road but the fastest engine to date on drag racing has been the Virtus by far! I tried all the top Nova engines and the Virtus currently holds the record on IMDRA. The record was set early this year from a 1.46 to a 1.40 in 132 feet. That is a huge difference for our application. Again, I am not sure how that will translate to on road if it does at all!!
Oso787 is offline
Old 12-09-2015 | 09:57 PM
  #5044
yes totaly agree with you on this, inovations and exotic parts are rasing prices ,make an impression sometimes pump up the marketing but the results show its not always a wining recipy .also i respect ofcaurse novarossi patends cause they got us here today
nick m is offline
Old 12-09-2015 | 10:05 PM
  #5045
virtus is also wining at gt drag races and on road sessions ,as virtus has a exploding torque .but putting next to a sirio rr sti i was so disapointed a back to the basic engine like reloaf says is reaping all my novarossi engines , i was in to totaly surprise an old engine wining all tha drag races with all the cars ,we tried everything ,still she was passing first.
nick m is offline
Old 12-10-2015 | 05:37 AM
  #5046
Oso787's Avatar
I hear you Nick, there are some old engines out there that will run with the new ones. The old C4-C5 from RB is one of them but its nearly impossible to find parts. I did tried a lot of engines in the last two years (old and new) but the Virtus came on top with the Picco Top Gun coming in second. I will tell you, its not much about mods as it is more about tunning!!!!!
Oso787 is offline
Old 12-11-2015 | 06:02 AM
  #5047
so now we have the answer about what engine was using kurzbuch ,it was a mito c based but with different sleeve ,different crank and differences also at the crankcase,novarossi released this engine.http://www.novarossi.it/2012/index.p...on-engine.html
nick m is offline
Old 12-17-2015 | 02:44 PM
  #5048
JamesHealey's Avatar
The Keep-On / Virtus and Mito 9 engines with a longer stroke, have a great bottom end power and acceleration, which at some tracks is going to be faster than the old screamers like the 35 Plus 21 & Flash Tuned.
The Mito 9C and Mito 35 WC are currently the top of the line engines for Novarossi, they've returned to an older philosophy of engine design of which they were very clearly good at too!
I don't think in on road there is any substitute for RPM and we all want that, Novarossi are delivering on that at the moment, don't get too hung up on the fact they look like they've made a step backward, they haven't! simply in the right direction.
JamesHealey is offline
Old 12-17-2015 | 04:10 PM
  #5049
Roelof's Avatar
All I see is an engine with a normal long stroke (16.22x16.8), a center positioned carb, a normal 14.5x26x6 main bearing and (sadly) a 7x19x5 main bearing. Basically how the Flash was designed.
Other sleeve, crankcase and crank I do not see. Maybe it is that I do see it different because the performance of an engine is made by timings and materials and not by partnumbers. Maybe it is also because I have seen many same model Novarossi engines with all different timings.
Roelof is offline
Old 12-18-2015 | 07:58 AM
  #5050
yes a litle change in timing can do a difference for demanding races .comparing the long stroke withe super long stroke i was untill now having luck with the 16.26 -16.80 .i mean normaly long stroke.when ever i tryied super long stroke.i want your experince roelof and from other people here ,maybe iwas doing something wrong ,just comparing 16.26 -16-80 engines with 15.88-17.60
nick m is offline
Old 12-18-2015 | 08:10 AM
  #5051
i know that tornado is a old fuel but i was having also big luck with it over all these years with my novarossi and other engines ,i have tryied almost all and end up using tornado or o donel , rapicon was a strange suprise also in drag races the 30 per cent. i dont want to start any fight just the good recipy the latest 5 years was 16.26 -16-80 engines and tornado or donel.what was your good set up recipy stroke profile and fuel i mean
nick m is offline
Old 12-18-2015 | 09:00 AM
  #5052
Roelof's Avatar
I never had runned an Xtra long stroke but last I had a Virtus to change the bearing and when I measured the timings I noticed it had a wider crank timing and a lower exhaust timing from what I used to see from Novarossi. And this year I had a Flash I modified and I must say it was fast but my N21-5T engines are also capable to keep up the faster models.
It is waiting if ever such a Mito 35 fall into my hands so I can measure it. I hope it is reasonable priced.
Roelof is offline
Old 12-18-2015 | 09:41 AM
  #5053
.yeah mito 35 won such a race now we are expecting the oportunity to see internals and to squeeze the hell out of her over 40.000 rpms.my experience with virtus is a exploding torque over on road cars but nothing so good riding gt s ,strange feeling.Roelof what fuel are you using?
nick m is offline
Old 12-18-2015 | 10:09 AM
  #5054
Having run the RB CXR and CXR SLS DI9, which were essentially Flash and Keep On based engines, lap time wise they were identical, but the power delivery was completely different, I prefer the long stroke engines (16.8) and not the extra long stroke (17.6)..
Old 12-18-2015 | 10:10 AM
  #5055
Roelof's Avatar
I normally drive with Runnertime.In my opinion the best you can get.
Roelof is offline
