Like Tree195Likes
Novarossi engines thread
Old 02-17-2016 | 03:49 AM
  #5101
Roelof's Avatar
It can mean a lot, just feel the pinch at the first shut down when it is cooled down. If the piston did not gat a kind of heat treatment in the factory the pinch will get bigger.
Just be carefull and be sure how the piston will act during the break in before you push up the performance.
Roelof is offline
Old 02-17-2016 | 10:17 AM
  #5102
vivo quevas's Avatar
You maybe right the pinch feels stronger after the first tank I will run many tanks before I do any performance tunimg.
vivo quevas is offline
Old 02-17-2016 | 11:02 AM
  #5103
Roelof's Avatar
Yes, heating up piston material and cooling it down does change the material on molucair level giving some grow. It depends the used materials in the piston aloy and if the piston already did got a heat treatment. So yes, the loose pinch is choosen to the behavour of the piston.
Roelof is offline
Old 02-17-2016 | 07:05 PM
  #5104
Default KHM MEGA .21
I thought I lost it many years ago, but in cleaning out my garage, fallen behind a workbench, I found a MEGA / KHM .21 new, inbox, never been started, with booklet, serial sheet and case I.d. by Klaus Hienz Meier. I remember purchasing 4 of these engines back in the VETEQ days and all this time it was behind my workbench, should I keep it as vintage?, or put it up for sale?
gwilli2001us is offline
Old 02-18-2016 | 10:41 AM
  #5105
dan_vector's Avatar
Wow I had one of those. It was a killer hand modified engine back in the day!! It may fetch some decent money to a collector as they are extremely rare.
dan_vector is offline
Old 02-19-2016 | 10:02 PM
  #5106
Originally Posted by NickTheGreek
Thanks.....
Is there a way of knowing exactly what that serial # is???
.......This is what I want to throw it in....
nice engine ,,,where are you going to race with this ,,north greece or in athens tracks?
nick m is offline
Old 02-20-2016 | 01:05 AM
  #5107
the cooling head is similar with this---http://www.novarossi.it/2012/index.php/en/out-of-production-engines-nova/rx21r1wcs.html
nick m is offline
Old 02-20-2016 | 04:51 AM
  #5108
Giasou re manga.....
That looks pretty much just like it....I'd like to know who exactly put the serial numbers on there...
I'm in New York but I don't think I'm gonna be running this particular car/engine anywhere.....It's probably just gonna spend its days on the shelf....
Hopefully I get to fire it up later today for the first time, give it a spin in the parking lot and then send it into retirement....
NickTheGreek is offline
Old 02-20-2016 | 04:56 AM
  #5109
Old 02-20-2016 | 06:37 AM
  #5110
αν θελεις κανε add sto face Nikos Rctuning
nick m is offline
Old 02-26-2016 | 07:50 PM
  #5111
Originally Posted by YANMAN
What pipe and header so you recommend with the legend .12R?
Hi Yanman, did you receive the Mito 35 GT5 engine?
rptech1 is offline
Old 02-26-2016 | 07:54 PM
  #5112
Originally Posted by desotoracing
Hi how is the performance of the Mito GT engine.. Rob
rptech1 is offline
Old 03-02-2016 | 09:14 PM
  #5113
dameetz's Avatar
Default Nova MITO 9 onroad
Anybody using this engine? Its the xtra long stroke one with steel bearings. Hows the performance difference with the long stroke MITO 9C?
dameetz is offline
Old 03-03-2016 | 10:40 AM
  #5114
snuvet75's Avatar
If I were to use Keep on .21 crankcase with Bonito .21 sleeve, would it work? the cases of both must be different but I just wanted to ask. Bonito is 7 ports and keep on 9ports. Everything else is Keep on's.
snuvet75 is offline
Old 03-03-2016 | 11:00 AM
  #5115
snuvet75's Avatar
Could anybody post an exploded view for Tesla .12? Couldn't seem to find it online.
snuvet75 is offline
