Like Tree195Likes
Novarossi engines thread
Old 12-18-2015 | 10:15 AM
  #5056
JamesHealey's Avatar
As far as Novarossi engines go, I still think the 35 Plus 21 & Flash engines were the best engines they ever made, the Kangaroo was also great! But didn't have the bottom end grunt of the later engines.
Everything after the Flash PT was questionable imho, I'm very glad of the direction Nova have taken with the Mito 35WC.
JamesHealey is offline
Old 12-18-2015 | 12:15 PM
  #5057
it was a bet of 4-5 years ,everybody was saying that novas will let the long stroke style engines at on road set up and that they will only work on extra long stroke ,i am glad also with their new direction with the mito 35 wc .
nick m is offline
Old 01-09-2016 | 05:57 AM
  #5058
can someone please explane the B line plugs, looks like the information on
novarossi site is in italian.i will be runing a keep on 21 on 16% nitro in the uk.
thanks rick..
rick oxley is offline
Old 01-10-2016 | 09:26 PM
  #5059
whats the xtra long stroke all about? i see the con-rod is the same length... can some one educate me?
fuse01 is offline
Old 01-11-2016 | 12:35 AM
  #5060
It's not about the conrod length, it's about the distance how far the crankshaft pin is from the center of the crankshaft rotating center..
-X-
35Plus21 is offline
Old 01-11-2016 | 01:33 AM
  #5061
Roelof's Avatar
The longer the distance of the crankpin from the center the more torque it can generate (standard physics).
Roelof is offline
Old 01-21-2016 | 01:18 PM
  #5062
New Novarossi GT engine
MITO-35GT5 $350
Available in about 2 weeks
desotoracing is offline
Old 01-21-2016 | 02:19 PM
  #5063
Any specs or exploded views?
CDS70 is offline
Old 01-21-2016 | 02:47 PM
  #5064
afm's Avatar
afm
MITO-35GT5 $350
Will you be selling it??...pre-orders?? how and where??
AFM
afm is offline
Old 01-22-2016 | 12:15 PM
  #5065
vivo quevas's Avatar
Default Is a keepon the same as a flash .12
I have a Nova keepon .12 and I want to replace piston and sleeve. I believe a flash .12 is ts basically the same internally and my question is that true second question is if this is true will a flash .12pt piston and sleeve work in my keepon .12? Or do I need to use flash .12 piston and sleeve? I see on the pt has 3 holes under the exhaust port that the flash .12 doesn't have.
vivo quevas is offline
Old 01-22-2016 | 01:22 PM
  #5066
AFM
Yes, we will have them in stock shortly.
The engine is based on the WC winning 8th scale motor so it should be fast!
Old 01-23-2016 | 07:17 AM
  #5067
dan_vector's Avatar
I need to pre-order that bad boy!! Can't wait...
dan_vector is offline
Old 01-23-2016 | 07:24 AM
  #5068
dan_vector's Avatar
you need P/N 08677/11 which is the same as the FLASH PT. The older flash was slightly different 08677/10. It would fit but if you can get hold of the keep on/flash pt version then I'd stick with that.
Old 01-24-2016 | 07:00 PM
  #5069
YANMAN's Avatar
Anyone have any experience with the Mito .12?
YANMAN is offline
Old 01-24-2016 | 07:03 PM
  #5070
Sure, what is your question?
DJ Apolaro
dj apolaro is offline
